HatersGonnaHate Posted August 27, 2011 Report Posted August 27, 2011 If you want to change the tone of your exhaust and Tennessee doesn't care about emissions testings, then cut off the cat and weld the glasspack in it's place and that should take care of it hopefully. I'd still recommend getting the tests done instead of throwing money at it and it doesn't fix a thing. I think my buddy went through $700 replacing all the sensors and not running any tests. I tested for vacuum, changed the cat and it was fixed! And he was pissed lol. Should be an easy and cheap fix man. yeah man im getting tired of spending money and nothing working lol. but like i said i replaced the cat with a glasspack so i guess now i need to do a vacuum test? Yea just get some tests run and hopefully they can find an easy cause to the problem. My name is AdamThis is my Civic Build.7" Samsung Tab 2Kenwood KDC-X896Clarion EQS746Sundown X-15DC 3.5k @2ohmHatersGonnaHate's 02 Civic UBLELD Bypass for Honda Civic/Accord/FitDon's Jeep Grand Cherokee Rebuild N8ball2013 - i think you'd stick your dick in a blender if it told you it was 40 wtih two kids your age. lol srp365 - If posting were picking up bitches, I'd be going home single tonight looks like tony montana sneezed in your car.
MrSkippyJ Posted August 27, 2011 Report Posted August 27, 2011 hey sweet, another TN member! TN does care about having a cat, but depending on where you live it may not matter or not. F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69
EvanSpurlock Posted August 27, 2011 Author Report Posted August 27, 2011 hey sweet, another TN member! TN does care about having a cat, but depending on where you live it may not matter or not. iv never been pulled over for it so i guess its all good lol
just1moreamp Posted August 27, 2011 Report Posted August 27, 2011 Check you fuel psi-needs to be atleast 35psi when hot if not change your fuel pump,,takes about 3hrs to change
EvanSpurlock Posted August 27, 2011 Author Report Posted August 27, 2011 Check you fuel psi-needs to be atleast 35psi when hot if not change your fuel pump,,takes about 3hrs to change i though it should be about 60?
vettedude102 Posted August 27, 2011 Report Posted August 27, 2011 hey sweet, another TN member! TN does care about having a cat, but depending on where you live it may not matter or not. iv never been pulled over for it so i guess its all good lol I'm in TN too haha. 2 polk audio 4x6'skenwood head-unit 220 amp Mechman alt1979 Corvette 2003 corvette z06 alpine radio and the bose system that came stock
HatersGonnaHate Posted August 27, 2011 Report Posted August 27, 2011 Yea you can check fuel pump operation, psi, and check all the seals around the fuel "spider injector" and make sure all of those "legs" off of the spider are clean. My name is AdamThis is my Civic Build.7" Samsung Tab 2Kenwood KDC-X896Clarion EQS746Sundown X-15DC 3.5k @2ohmHatersGonnaHate's 02 Civic UBLELD Bypass for Honda Civic/Accord/FitDon's Jeep Grand Cherokee Rebuild N8ball2013 - i think you'd stick your dick in a blender if it told you it was 40 wtih two kids your age. lol srp365 - If posting were picking up bitches, I'd be going home single tonight looks like tony montana sneezed in your car.
OLDSKOOL78302 Posted August 27, 2011 Report Posted August 27, 2011 Have you checked for error codes? HEAD UNIT JENSEN VM9312 4 12" KICKER COMPS 4 PUNCH 150 AMPS "0NE ON EACH SUB" 2 ALPINE 3522 ON MIDS AND HIGHS MLA MOD BIG 3 OPTIMA D31T BATTERY UP FRONT, ANOTHER IN BACK 2 KINETIK BATTERIES IN BACK ALSO"ONE 800,ONE 1200" DUAL ALTERNATORS "ONE 200 AMP" OTHER MECHMAN 270 LARGE CASE
EvanSpurlock Posted August 27, 2011 Author Report Posted August 27, 2011 Yea you can check fuel pump operation, psi, and check all the seals around the fuel "spider injector" and make sure all of those "legs" off of the spider are clean. yeah i clean the "legs" the best i could with some carb cleaner
OLDSKOOL78302 Posted August 27, 2011 Report Posted August 27, 2011 Kinda sounds like your map sensor.jmo HEAD UNIT JENSEN VM9312 4 12" KICKER COMPS 4 PUNCH 150 AMPS "0NE ON EACH SUB" 2 ALPINE 3522 ON MIDS AND HIGHS MLA MOD BIG 3 OPTIMA D31T BATTERY UP FRONT, ANOTHER IN BACK 2 KINETIK BATTERIES IN BACK ALSO"ONE 800,ONE 1200" DUAL ALTERNATORS "ONE 200 AMP" OTHER MECHMAN 270 LARGE CASE
