Those trucks also have resonator in front of the cat as well that can also become clogged. And you need a cat on that truck or it tuned with EFI live so your PCM doesn't throw it into super rich mode.
TEAM SOUNDQUBED -- TEAM SOUTH
TEAM S.O.B. - Founder & Captain
3x Streetbeat World Record Holder
2017 MWSPL 1st place Mayhem & 4th Xtreme 4
2016 MWSPL 1st place Mayhem/2nd Adv 4/2nd Xtreme 4
2015 MWSPL 2nd place Mayhem & 4th Xtreme 4
2014 USACI 2nd place Streetbeat 5 - 162.6 db
2014 MWSPL 2nd place Xtreme 4 - 144.9 db
2013 USACI 1st place Streetbeat 4 - 161.9 db
2013 USACI 1st place Street Q+ - 162.8 db
2013 MWSPL 3rd Kaos2 & 4th Xtreme 4
2011 USACI 2nd place MOD 1001-2k - 160.0 db
2011 MWSPL 4th place: Adv3 - 157.8 db, Kaos2 - 150s db, Xtreme4 - 140s db
2010 ARSPL 1st place 501-750 - 160.3 db Arkansas loudest
Best score to date 164.4 db - Termlab Outlaw
MWSPL on Dash Legal door open (Music) - 162.5 db
Sealed on dash Legal (Music) - 161.1 db - Termlab
THE BLACK NASTY CURRENT BUILD & FAB
The Black Nasty (6) 15 Rebuild Log 2012
(4) 15 Walled Sierra Build Log
Evo X build log
Facebook page The Black Nasty
Well well well I guess my 2 cents are needed seeings I'm in TN and drive a blazer and holy crap! A lot of things can go wrong here's the list I know of
1 Intake gaskets
2 EGR
3 TPS
4 IAC
5 fuel pump or filter clogged
6 bad O2
7 running anything but Delco plugs
8 clogged cat
9 vac leak under hood
10 vac leak under dash errrrrrrr
11 vac diaphram stuck/leaking (4x4)
12 spider injectors
Sorry if I left anything out but still a good check list
Hope it helps from Madison County
Kenwood KIV-BT900
Front Stage
RF 400-4 Runs off dedicated 4 awg ofc
RE 6.5 125.5.
Lanzar Max Pro 6.5
Boston S60 6.5 components
Rear
Soundstream BX-15
4x Sundown SA8 v1.5
Crescendo BC3500D
2.4 net 28hz
4 runs of 0 gauge
Big 3
HC2400
700ca up front
Singer 350 Amp Alt
No deadener :/
Scytek Galaxy Alarm
so replacing the cat with a glasspack was a bad idea? and it was messing up with the cat on it?
i know in the older models ( 97) the ignition switches would go bad.. causing similar problems
1998 gmc extd cab
12 crossfire C710s
4 SAZ-4500s
3 Singer 400A alts
buncha mids/highs
Team Asshole
Yes bad idea, and was probably not the cat then if it is doing same problem.
Evo X build log
anybody know how to check for vacuum and what it should read?
WIth a boost/vaccum gauge T-tapped into a vaccum line on the intake mani. Should read in the -15 to -20 at idle. And go up to 0 when you hit the gas.
Evo X build log
