DC Sound Lab
Ok so I have to dual.7 dc xl 12 an I'm looking to upgrade my amp. For electrical I have 2 d3100 right now an dc power Alt 270. I was thinking bout a dc 5k but my rise is almost at 2 ohms so I won't get all the power out of it so what about a dc 7.5k? I know it's more power but after u set the gain for clipping do u still get 7.5k at 1 ohm? Or any amp in general after you set the gains do they still rated
Help guys !
Edited by EdgarG0721
Would 2 3.5k be more efficient n is it safe to start them at .7 ohm before rise?
with 2 3.5ks, if you strapped them at .7 that would be .35 per amp, i wouldnt run that low, espically daily
2014 Chevy Silverado Crewcab
1994 Chevy Full Size blazer
I tought if I wire them series/ parallel both subs I end with a .7 load when u strap them ? Is my math wrong? I get confused with ohms
with strapped amps, your final ohm load is divided between the two amps.
so if you strap @.7 ohm, each amp will see .35 ohm before rise
Honestly i would just stick with the 5k. When dealing with a daily setup I would not count on rise at any point because it changes with every frequency played.
  • Who's Online   0 Members, 0 Anonymous, 4589 Guests (See full list)
