Hey SMD,
My dumb Ford Focus can't fit a 8 cubic feet box with room for more batteries and amps. I had a 15" and it took up alot of room. So I thought if I build it inside the trunk I could fit two 15" sealed off from the trunk. It's not going to work out.
My question....
Should I go with two 12"s or three 10"? Yes I want loud or I would have stayed with one 15"
Either Sundown Z or Fi Q
Sealed off from the trunk subs and port into cabin.
Using a DC 9K or 7.5k running at 4 ohm.
No rush, just want some input from all you knowledgeables so I can start planning
Thanksies
Google it
I feel your pain bro.. I lost my back seats because I couldnt put 4 15".. but hey I dont need passengers in the car, 1 is good enough. lol
2004 Melky Toyota Scion xB
Kenwood Touchscreen Headunit
4 15" Kicker CVR
4 6" Audiopipe
6 8" Audiopipe
6 Tweeters Audiopipe
1 Rockford Fosgate T2500.1 bd
1 Lanzar 3000
1 Audiopipe 1500
2 Optimum YellowTop Batteries
The Big Three
19" rims
and more..
http://www.stevemeadedesigns.com/board/topic/119197-build-log-scion-xb-4-15-kicker/
Three tens would have more cone area and motor force. And why would you only run at 4 ohms?
Big 3 with Yellow Top
Thats true. He should definitely go with 3 10" and wire it to .97 ohms.
4 15" Kicker CVR
4 6" Audiopipe
6 8" Audiopipe
1 Lanzar 3000
1 Audiopipe 1500
The Big Three
19" rims
and more..
Can't run at 1 ohm people, not enough power from the alternator. So run like 3k RMS at 4 ohm :) I can't do a wall because I built panels for the back doors and my middle seat is a console with two 10"s and an amp, way too much work and money to just scrap :( Wall in my next car for sure.
so three 10"s?
Google it
so three 10"s?
Hold on. Someone correct me if im wrong but power is power. If you are making 2000 watts at 4 ohms or 2000 watts at 1 ohm wont you pull just about the same amount of power?
Cleaner power...less heat. Basically, more efficient, look at any amp's birthsheet...the efficiency is amazing at 4 ohms. I have a Mechman 200, can't fit a bigger one, and three Kinetik 1400's. Want to add 2 more.
I don't mind paying for a 7.5k, should never have the need to upgrade an amp :)
Edited by monkeyleg
Google it
