I think ive had over ten set ups in my trailblazer ranging from 18's to 15's, which all took up around ten cubes, however, Im doing a few performance mods and want to downsize my system from having a ten cube box to something more convenient. I know i can go smaller and still be around a 150db.
I have 1 15" BTL n2 left, and two amps laying around: orion 2500 as well as an xxx4000 soundstream.
i plan on sub up port back, but my goals are to stay clean, 4-5cubes max, and over a 147.x.
What would yield better results, keeping the 15 and doing a crazy box design ex. aeros/4th order/t-line.
Or going with a little more cone area like 2 12" hdc3s with a slot/aero port? I plan on having ram designs do the enclosure again, i just need a little advice as to what combination should work the best.
With that power id do 2 12's
Like Ray said, 2 12s. You'd need more space for a proper 4th order for that 15", not to mention that powers pushing it. Cone area+motor force = :woot:.
Edit: Thought the XXX line did over rated. Maybe thats at higher voltage. :Doh:
Edited by tonedeaf
4 10s youd probably be looking at 1.2-1.6 per 10 depending on the subs, so you could make it within spec. But how much money are you wanting to spend. Cone area goes only so far when it comes to number of subs IMO.
