CJs F150- 8/10..1 9k??? Nope....2!!!!
Is there a reason why your shrinking the port did it not sound good? I thought you was happy with it
I am tweaking the size and ratio of my chambers, so I have to change the port as well. The port that I had in was just a temporary build until I had time to build the one I am working on now.
Todays progress.
Shrunk down my ported chamber to get my ratio back where I want it to be.
Also installed 6 new blue LEDs. This suckers are bright!
This is with 2
Now with 4
Now with all 6
Working on the new port. I am having to use the port to take up some more airspace to get me to the airspace that I need.
I have to go to Lowes in the morning to get some more PVC, what I had wasnt long enough for my side panels. Once this is done, I will wrap the front, paint the PVC and the inside of the port and it will be done.
Nice.... how's it sound
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
Dont know yet. I did play it for a few days before making the changes and it sounded good. The biggest change this time is that I mounted the subs normally instead of inverted, so I could shrink down my sealed side. Since I did that, my ratio became too big, this is why I am shrinking down the ported section as well. Hopefully it all pays off.
With those new lights that bright, your neighbors and other people might think a ufo landed..:lol: Great job bro.. I approve..:good:
Jay
  • Who's Online   1 Member, 0 Anonymous, 429 Guests (See full list)
