CJs F150- 8/10..1 9k??? Nope....2!!!!
Ok here are 2 dustcap options with cf vinyl. I had an extra one so I just used it.
What do yall think? Which would you do?
god damn dude, always love your work, TDH BITCH!
Legal TL scores145.6 on the dash sealed up in the low 40hz area with the port out145.5 on the dash sealed up @30hz with the port inless then 1k clamped on a 3.5k!
Why would you EVER WANT flex?
huh?...flex is what can make the lows lower and more air being pushed correct?
me_zps0fb5a5b4.jpgMy FeedbackJeep-BuildlogPT LOSER buildlog
I like all the caps the look awesome... curious to see you install new surround.. I've done or seen a lot of recones but never that done.. also when you getting the 12k?
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
I am hoping the surround install is fairly simple I know it will take me a good bit of time to do it though. Have to be very careful to make sure I dont damage the cone.
I just bought some blue cf vinyl that I think will be the final dustcap option that I will go for.
The cf and blue would look better since that's what colors u are doing
2 polk audio 4x6'skenwood head-unit 220 amp Mechman alt1979 Corvette
2003 corvette z06
alpine radio and the bose system that came stock
  • Who's Online   0 Members, 0 Anonymous, 1492 Guests (See full list)
