CJs F150- 8/10..1 9k??? Nope....2!!!!
what size and man those alts look good
TEAM DEADLY HERTZ BITCHES
1/2" It wont look like it will fit but it stretches out and works great. Kind of like a chinese finger trap.
Got to say your electrical is better than mine if your not dropping.... what ohm load are you going to wire the 12k too?
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
.67 I think I might try .33.
I will do alot more testing tomorrow. The only thing I am really worried about is massive RPM loss when the alts load down. I dont know if it was that or my foot slipping off the pedal but we will see.
The next thing on my to do list is an external throttle control to solve that issue. I am also going to look into raising my idle set point from 800 to 1000-1200.
man those are some sexy alts, did you score increase with the new alts?
Jeep Cherokee 4dr -4.75 in front, new rusty's 4.5 in rear leafs -micky thompson 35x14.50x15 -locker rear -Rusty's offroad Engine/transmission/transfer case/crossmember/gas tank skid plates -Warn front bumper with 8000lb winch -Custom rear bumper -Warrior product tube doors (summertime) -Optima redtop (starter) -26XK miles and still runs like a bat out of hell
Kenwood H/U
1/0 wire,
136 amp alt 200 ah batteries 12.7 daily
2 Apsm 1500 @ 2 ohm strapped on zv3 d1 with ns softparts
Mb quart 125.4 wired to 4 aura 6's
3.6 cube box tuned to 36 plays down to 23hz
First test saw a .35 increase and that was with the amp tuned lower than before.
if you have a programmer that should be pretty easy to do . . .
i have mine @ 950
damn your score is slowly climbing, youll be at the 155 in no time :D
Kenwood H/U
1/0 wire,
I think I can get the 55 tomorrow with setting the amp for burp. So far the highest score I have seen with the Level 3s was with the 12k. 154.77.
When I swap in the XLs on the 7.5k, I expect to see 155+ and when I add the 12k to the mix I am hoping for 156+. Maybe lofty goals but that is what I am hoping to see.
  • Who's Online   0 Members, 0 Anonymous, 1426 Guests (See full list)
