What year is the vehicle? If it is post '96, there should be a plug under the driver side dash. Any flash tuner can read codes, too. SCT, Diablo, those type of things. If you take it to a shop, they will charge a stupid amount to plug it in and tell you whats wrong.
AutoZone does it for free ;)
Kenwood KIV-BT900
Front Stage
RF 400-4 Runs off dedicated 4 awg ofc
RE 6.5 125.5.
Lanzar Max Pro 6.5
Boston S60 6.5 components
Rear
Soundstream BX-15
4x Sundown SA8 v1.5
Crescendo BC3500D
2.4 net 28hz
4 runs of 0 gauge
Big 3
HC2400
700ca up front
Singer 350 Amp Alt
No deadener :/
Scytek Galaxy Alarm
I'm gonno go with krypto at this point... does your thermostat housing have a bleeder screw? Or a return hose going back to the overflow pressure tank?
No. Return hose connect to the bottom hose on the radiator
There you go, Toad.
SMD Super Seller
My Feedback Thread
So do this first then?
if its driveable yes but if there's an air pocket or bubble in the cooling system it will do funny sh!t if your overflow hose is clogged it will also do funny stuff
Kenwood KIV-BT900
Front Stage
RE 6.5 125.5.
Lanzar Max Pro 6.5
Rear
Soundstream BX-15
4x Sundown SA8 v1.5
Crescendo BC3500D
2.4 net 28hz
4 runs of 0 gauge
Big 3
HC2400
700ca up front
Singer 350 Amp Alt
No deadener :/
Scytek Galaxy Alarm
Posted (edited)
If your truck is a 1996 or newer it should be OBDII. The gov made it required on 96 but some companies drug their rearends till 98 on geting the system going. That aside I would be tempted to agree with the gentleman who said the cool temp sender may be bad. Best way is to plug in to obd connect and watch what the temp says it is doing. Most cars have a coolant temp sensor and a temp sender which makes it really easy to see if one is bad. they dont match up that simple. Another way would be get an infrared thermometer and read the hose as it comes out of the thermostat it will prob be a few degrees off but close enough to tell if the temp gauge is reading accurately. Also do not discount that the temp guage could be bad, it happens but I would not worry even if you replace the sender they only cost 15-20 on most vehicles so no big heft if the problem did end up being the gauge. To read coolant hose out of the thermostat housing the thermostat must be open or removed
Edited by photochrisb931
Barstad
  • Who's Online   0 Members, 0 Anonymous, 880 Guests (See full list)
