I Feel my DD has alot more potential
Stee-Z
My setup... DD 9515... AQ 2200... XS D3400.... and a poopy old pioneer headunit ( for now) 5 ft3 @ 30 Hz
I just have this feeling my system should be hitting harder. Because whenever i turn it up to an o.k. loud my AQ bass knob has the clipping light come on... its gay ha.. and yes i did just kind of no brain the gains by myself =(.
My headunit is on vocal also.. so thats about the least amount of bass from the setting, but otherwise my GAY headunit , on any other setting such as supe bass boost..fail.. or rock etc.... makes it so i can barely hear the words and gives me mostly bass
Could my system have more potental if i get a better headunit..which i am... and/or have the gains set with an osciliscope?... any pointers would be great thanks :yahoo:
(4)DD 9918's
(2)DC 10k
8 6.5" focals
2 DD SS4 mid amps
Audison Bit One processor
Jl-cl-rlc line driver
iPad in dash
Dual Irragi 320a alts
8 batcaps 4000's
Second Skin sound deadened
Tune higher 35 at the lowest trust me. Also that clip light isn't the most spot on. Os it solid or just a flicker
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Yrs if you have like 2v rca jacks on the HU and you get 4v or 5v it will deff. Make a diff.
145.9@40hz
145.3@34hz
big 3
X2 group 34
Deka Group 31
All 0/1 awg jl meta wire
Alpine CDA 7894
Orion HCCA D5000
2 AQ HDC312's
Crunch gpv1100.2 (for 6.5"s only)
AQ pro audio 6.5" - 3 sets
AQ supertweeters - 2 sets
2000 Slamry
My 9515s didn't come alive until 3k plus each
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
How are your tinsels weak when dd only does direct leads. Unless you weren't talking about digital designs of course
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
  • Who's Online   0 Members, 0 Anonymous, 1133 Guests (See full list)
