how to hook up an extra battery?
quick question fellas.
okay, so to add 1 extra battery in the trunk of a car/truck/suv whatever, all you need is 1 run of positive and 1 run of negative from the front battery to the rear. and then from the rear you can power your amp from that? or how does it work? example:
xs d3400 in the front
1 postive and 1 negative run to the rear which would be a xs d3100 and then lets say a rockford bd2500 amp to be powered by that rear batt?
thanks guys :)
system is going to consist off 1 18' btl and a rockford bd 2500.
Sounds good, but if i remember correctly, you'll want to fuse between your two batteries just in case something shorts out. Your vehicle wont go up in flames
I do 2 fuses (ANL) 1 At the front one at the back so if theirs a short anywhere in between your covered.
Edited by EBW
Kenwood KIV-BT900
Front Stage
RF 400-4 Runs off dedicated 4 awg ofc
RE 6.5 125.5.
Lanzar Max Pro 6.5
Boston S60 6.5 components
Rear
Soundstream BX-15
4x Sundown SA8 v1.5
Crescendo BC3500D
2.4 net 28hz
4 runs of 0 gauge
Big 3
HC2400
700ca up front
Singer 350 Amp Alt
No deadener :/
Scytek Galaxy Alarm
yep fuse the batteries. you dont really have to run negative though cuz its ground to your car and engine so mostly run few grounds to body in back and its good.
1996 dodge stratus
audiopipe 3k
2 15 american bass xds
10 door speakers threw out car
kenwood head unit.
spl scores from trunk: 147.7db on 2k
extreme out side window-129.2db
kaos 3 min average music-138.3db
really, no need for a negative run?
I run a neg back to the frame then a run from my amp/batt ground to frame at the same location. And 2 300 amp fuses should be good 1 up front one at rear batt
Edited by EBW
Kenwood KIV-BT900
Front Stage
RE 6.5 125.5.
Lanzar Max Pro 6.5
Rear
Soundstream BX-15
4x Sundown SA8 v1.5
Crescendo BC3500D
2.4 net 28hz
4 runs of 0 gauge
Big 3
HC2400
700ca up front
Singer 350 Amp Alt
No deadener :/
Scytek Galaxy Alarm
so you run a negative wired from the front batt thats grounded in the rear of the vehicle, and you ground your amp and the rear batt to the same location?
