I need a little help with which Amp I should get. I will be getting these Subs {http://www.bestbuy.com/site/Kenwood+-+Performance+Series+12%22+Single-Voice-Coil+4-Ohm+Subwoofer/1989356.p?id=1218304511834&skuId=1989356} and I need some input on four Amps I've found.
1st: http://www.amazon.com/AUDIOPIPE-AUDIO-AQX400-2-Channel-Amplifier/dp/B00424RLW0/ref=sr_1_1?s=electronics&ie=UTF8&qid=1314684612&sr=1-1
2nd:http://www.amazon.com/Lanzar-MXA414-Channel-Bridgeable-Amplifier/dp/B002UL5VKQ/ref=sr_1_54?s=electronics&ie=UTF8&qid=1314695618&sr=1-54
3rd:http://www.amazon.com/Legacy-LA1089-Channel-Bridgeable-Amplifier/dp/B002UL7YJC/ref=sr_1_66?s=electronics&ie=UTF8&qid=1314695618&sr=1-66
4th:http://www.amazon.com/Lanzar-MXA244-Channel-Bridgeable-Amplifier/dp/B002UL49D6/ref=sr_1_215?s=electronics&ie=UTF8&qid=1314696647&sr=1-215
I am leaning towards the 3rd one but I'm not reaaly sure. Any help would be great. Thanx.
What is this going to be powering?
And what is your budget?
Edited by BJD3
DC Level 4 M2 12 D2
Car Audio Bargain 1600.1
Eclipse CD3200
~2 cubes @ 34 hz.
Stinger Roadkill Expert
Honestly I wont recommend any of those amps b/c I bet you can get a better amp for around the same price
Edit: if those are the only amps you will look at go with the audiopipe.
Edited by bassrace
145.9@40hz
145.3@34hz
big 3
X2 group 34
Deka Group 31
All 0/1 awg jl meta wire
Alpine CDA 7894
Orion HCCA D5000
2 AQ HDC312's
Crunch gpv1100.2 (for 6.5"s only)
AQ pro audio 6.5" - 3 sets
AQ supertweeters - 2 sets
2000 Slamry
Amp
Subs
Wire
Should be right around the same price.
Go buy a sheet of 3/4 inch MDF and build a box. I'd avoid a prefab if at all possible.
Yes, I've had this budget build planned for quite some time. I've just never had anywhere to put it.
EDIT: I'd like to point out, there are many, many different variations of high output, low cost systems. This is just one example.
And likely one of the most common on this site.
Edited by BJD3
DC Level 4 M2 12 D2
Eclipse CD3200
~2 cubes @ 34 hz.
Amp
Subs
Wire
good choice. cant go wrong with any of those :)
Amp
Subs
Wire
Ive never heard those subs before. But very good wire and a good amp also.
My priceline is under 150 dollars for an amp. I already have wires and those kenwood subs ordered.
If those amps arent any good which ones are for my priceline..
Edit: I am getting 2 subs so I need at least a 2 channel amp..
Edited by Magna94
