from what ive been told they are real strong batts
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
very strong batteries, I use them in two of my cars.....Odyssey and Powermaster are the only batteries I use
Team Devastation Mixed Martial ArtsMachado Brazilian JiujitsuOnce I lock it on there's no escape I don't train to make you tap, I train to tear your arm, leg, or head off. Its your job to tap before I can do that -Pain is only weakness leaving the body, its kill or be killed and only the strong survive...Rockford FosgateDigital DesignsFi Car AudioCrossfire Car Audio
Odyssey,Stinger,hawker,and Diehard platinum are all the same batts and are all good..hope this helps..
2000 Suburban 6 runs of 2/0
12 JBL Pro audo mids ,6 timpano audio tweets and 1 Prv compression horn per door
475ah of yin long LTOs
Triple 370 Amp Autotech Alts
mids amps 2  Crescendo Skyway 3ks
compreesion horn amp crossfire 800.4
Tweet amp Crossfire 2000.4
sub amp: 4 Crossfire XT 8ks
Subs: 8 18 in Crossfires in a 4th order
Best Scores at events…
163.5@38hz DBdrag  sealed on the dash… 164.3 outlaw…162.9 Meca headrest
So 2 should be ok on a saz4500 425a alt
[/quote)
Yes I run a stinger sp 1500 under the hood and 2 die hard pm-1s in back(same as the 2150) and a 320a alt on a DD Z1a with zero issues
Drop to only 13.6-13.9
Edited by kalilac619
just make sure your wiring is on point and you will be fine.... I use 2 Odyssey 2150's on a pair of RF 2500.1's with a 260amp alt
