well just got this blown 12 today just for the motor, so when i pull the coil out this happends, the mags shift and collapses together, and to add to the pain the screws are soft and want to strip out. what is there to do to fix this or who can fix this.
A New Begining Starting Over
2003 F-150 extended Cab
Head unit: Pioneer 880
Speakers: JBL 6.5 comps and 8's in doors
Amp: JBL 100x4 & JBL GTO700.1
Sub Amp: ?
Subs: Possible 4 SX 15's or 2 SX 18's
Box:18-20 sq ft @ 30
Batts: Still Need
alt: mechman still to order
Wire: Lots of 1/0
i have that set, it will take out any broken, striped, or damaged screw with ease
Team sundownWESTCOASTSPL.COM we're throwing dbdrag events very soon visit the website for details
thanks for that, i got all but one, but the big problem is the motor, im hoping there is somthing to do. it looks like the glue gave way between the top plate and the slugs.
Sub Amp: ?
Batts: Still Need
Wire: Lots of 1/0
gotta have the motor DE-magged, taken apart, then re-centered/re-glued... sorry buddy, gotta go thru the motions
not many places but the manufacturer can even de mag it at all, its VERY dangerous to de mag, you can end up sending a motor right thru the cieling if a in-experienced person tries to de mag it...... if they have a 2 -4 million watt magnet charger
could fi do this,iv emaild them but im waiting on a reply.
Sub Amp: ?
Batts: Still Need
Wire: Lots of 1/0
they probably could, but i would imagine it would be expensive to de-magnitize it and then have to re-magnatize it...how much would that run, guesstimating, if anybody knows? if it cost as much as i think it does you may have yourself a pretty cool paperweight...
i likes me some audio stuff...
yeah more than likly with the way things are going
Sub Amp: ?
Batts: Still Need
Wire: Lots of 1/0
well finally got the basket off, took forever since one screw stripped out, found out thats its only the top plate that has come loose from the slugs.
Sub Amp: ?
Batts: Still Need
Wire: Lots of 1/0
