Finally checked my voltage today. This morning, idle voltage was only 14.1 with the car cool. This afternoon, idle voltage is 13.8-13.9, car hot. I would think that is bad, right? But drop is very good. Playing music full tilt, lights, fogs, full a/c, and defroster all on, the lowest it dropped was to 13.0. So is it bad that idle voltage is low, even though there is very little drop under load?
SMD Super Seller
My Feedback Thread
same thing in my mustang i believe its because our car is ecu controlled and its not goin give you any extra voltage all high if it doesnt have a load for use it own
idk i wordered it werid does that make sense?
CAR
-2005 Ford Mustang (Legand Lime)
H/U
-Pioneer avh 3200dvd
Amps
2 AQ 3500d.1s strapped 1ohm daily .25burps
1Sundown Audio 100.4
1 Sundown Audio 125.2
Subs
4 AQ HDC'4s 12's
Mids and highs
4 Sundown Neo Pro 8s
2 AQ Super Tweeters
Electronical
Mechman 270 unit
1 D3400
2 D3100's
WALLED!
Your mustang is controlled by the PCU I think, the computer tells it how high to charge. Only way I believe you can fix it is getting your computer flashed and it set higher, as I dont believe a VCM changes the problem since it doesnt bypass the computer.
Well, thats probably it. I know there's no VCM option for this car. There is no voltage option on my flash tuner, so that won't help. Oh well, as long as i'm staying above 13 volts full tilt, I guess I can't complain.
SMD Super Seller
My Feedback Thread
True. Getting it flashed professionally by a shop should let you adjust it, as it can adjust idle for example and so many other things...but im not positive. Supposedly mechman is working on a fix for the issue though that will be P&P IIRC.
i was thinking about flashing my mustang and to see if that was possible but i guess not
and yes he is working on it since he has a mustang as well he told me he wants to do a build on, but god knows when that will even be ready to the public :shrug:
CAR
H/U
Amps
Subs
4 AQ HDC'4s 12's
Mids and highs
2 AQ Super Tweeters
Electronical
Mechman 270 unit
1 D3400
2 D3100's
WALLED!
So the only thing this changes is I should probably put my batteries on the charger more often.
SMD Super Seller
My Feedback Thread
charger for me didnt do me no difference to be honest
CAR
H/U
Amps
Subs
4 AQ HDC'4s 12's
Mids and highs
2 AQ Super Tweeters
Electronical
Mechman 270 unit
1 D3400
2 D3100's
WALLED!
Ok, so here's a twist. I thought it was my car not allowing charging over 13.8, WRONG. Yesterday it was charging at 14, and today its charging at 14.2. Checked at the amp, front battery, and rear bank, all the same voltage. I would understand if it is cooler voltage may go up. But, it is a lot hotter today and the voltage is up. Still above 13 full tilt. I'm stumped.
SMD Super Seller
My Feedback Thread
Hmm could be batteries are a lil low so computer is telling it to charge at a higher voltage. I'm not sure what the regulator reads from and how it changes its charging rate. On newer chevy there's a thingy on the negative bat cable lol someone help what's the thing called
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
  • Who's Online   0 Members, 0 Anonymous, 1505 Guests (See full list)
