graham0599 Posted September 6, 2011 Report Posted September 6, 2011 So i was wondering if anyone used line drivers. What are the advantages of them really? Disadvantages? I was looking into getting 2 of these, one for the sub amp, and one for the highs amp. My headunit does 2V. The amps can take up to 5v. http://www.google.com/products/catalog?q=line+driver&um=1&ie=UTF-8&tbm=shop&cid=15524254499349594915&sa=X&ei=A2BmTvyHHuSBsgKLssWoCg&ved=0CJUBEPMCMAI My 350z build- http://www.stevemeadedesigns.com/board/topic/174424-2008-350z-build/page-2?hl=%2B350z+%2Bbuild#entry2605678
keepinitloud Posted September 6, 2011 Report Posted September 6, 2011 you will pleased with the dramatic sound improvement if you get a line driver but no need to buy two just find one that will accept a couple of inputs 06 chrysler 300C Hemi one mmatts dreadnaut 15 powered by a planet audio vx 2200d fosgate p200 running planet audio 8" midbass drivers and super compression tweeters stock battery and a stinger spv44 Irragi 300 amp alternator big 3 1/0 http://www.stevemeadedesigns.com/board/topic/55075-system-in-my-300c/page__view__findpost__p__763656__fromsearch__1
BJD3 Posted September 6, 2011 Report Posted September 6, 2011 you will pleased with the dramatic sound improvement if you get a line driver but no need to buy two just find one that will accept a couple of inputs Disagree. @OP You have a gain knob for a reason. A line driver will do you no good. It may even cause you issue since this is yet another place in which you can encounter ground loops. More here. http://www.stevemeadedesigns.com/board/topic/117986-2volt-4volts/page__p__1658122__fromsearch__1#entry1658122 Anti Peel and Seal...lol You may be offended by the above. Don't take it personally, I'm just abrasive. 2002 Buick Park Avenue DC Level 4 M2 12 D2 Car Audio Bargain 1600.1 Eclipse CD3200 ~2 cubes @ 34 hz. Stinger Roadkill Expert
Ray Posted September 6, 2011 Report Posted September 6, 2011 Higher input voltage is used to help fight induced noise 2008 California state record holder 157.2 Bassrace2009 California state record holder 157.0 BassraceRollin 50's 158.7db2009 King of Cali Bassrace2009 USACi score 160.5 @ 42hz
Derrick824 Posted September 6, 2011 Report Posted September 6, 2011 I use a line driver only cause it's easier to tune multiple amps. Gain match each amp at low volume then use the single adjustment of the line driver to dial them in at full tilt. Adding a line driver didn't any difference in my setups.
