I am going to throw this out there because i just got my car out of the shop 2 days ago. I was having issues with my throttle and they said i probably needed my throttle body cleaned and if that didnt work replacing my throttle body, which would have been about $800 for my Mazda 3.
But they cleaned and its running a little better now but from what I read once you get your throttle body cleaned it takes a while for the computer to get up to speed. :shrug:
I think in that case you'd have to clean the whole intake manifold & the maf...not sure if it works the same for the 3 as my car, but it is recommended to reset the ecu by disconnecting the negative battery terminal & holding the brake pedal for 30 secs. after doing work on the engine.
CHECK OUT MY MYSPACE; SOME PAINT WORK I'VE DONE: http://www.myspace.c...customcreationz
DODGE RAM 1500 QUAD CAB BOX BUILD: http://www.stevemead...showtopic=48978
DODGE RAM 1500 RUMBLEBEE EDITION CUSTOM ENCLOSURE: http://www.stevemead...showtopic=48983
PREFAB REMODELING: http://www.stevemead...box-remodeling/
G35 CUSTOM PAINTED L7 BOX: http://www.stevemead...om-painted-box/
CHEVY SINGLE CAB PAINTED SUB BOX/AMP RACK: http://www.stevemead...vy-boxamp-rack/
KICKER L512 BOX BUILT TO SPECS: http://www.stevemead...-kicker-l5-box/
RF HE2 10'S KERF PORTED BOX: http://www.stevemead...erf-ported-box/
2 DC LEVEL 3 15'S KERF ENCLOSURE: http://www.stevemeadedesigns.com/board/topic/115502-kerf-ported-enclosure/
2 HCCA 15'S PORTED ENCLOSURE: http://www.stevemeadedesigns.com/board/topic/129468-2-hcca-15s-enclosure/
Yea pretty much, holding the brake pedal is just to drain out any current left in the car's electrical system, & leave it disconnected for a few minutes.
