Modding a Battery Charger?
So I'm getting my Mechman 220 installed soon (like tomorrow maybe), and I need to charge my batteries up. I have a Shumacher charger that I got for like 35 bucks with the AGM setting and everything (XC10), but the problem is that the charger charges up to 15.5 volts even on the slowest charge setting. Now, when I got my XS Power battery, there was a big orange flyer that said to not charge AGM batteries over 14.4 volts. Now I am really strapped for cash right now, so I don't have the money to buy a charger that has adjustable voltage and all that. So I am wondering if it is possible to mod a battery chargers output voltage to a fixed voltage, or if anyone has ever done this before. Maybe even if it's not even internally modding the charger, just something to regulate the voltage the charger puts out. I don't want to ruin my batteries. Any help is appreciated!
My Channel on YouTube. Check it out for cinematic-style Car Audio videos.
https://www.youtube.com/channel/UCcSMhtT-rpopJbdybubDgnQ
New 2014 Scion TC 4th Wall Build
https://www.stevemeadedesigns.com/board/topic/217173-2014-tc-4th-order-build-3-fi-sp4-15s/
No one? :(
Maybe not even a mod, just a suggestion of a good batter charger that charges properly around 14.4-5 that wont cost me 200 dollars, if possible.
i would suggest getting a resistor on that charger you have. what kind of amperage does it output??
Those of you who are risking your relationships need to grow up. Bass can't make you sandwhiches.
You clearly haven't tossed lunch meat, cheese, and bread in your port yet. Makes a hell of a bologna sandwich salad. Jiggles the balls pretty good too.
If i ain't learning, I ain't living.
Steve blocked me on YT... I think i irritated him a few years ago.... LOL sorry man
I don't have any serious builds goin on... currently i have an Interfire IF-2400b pushing 2 Alphasonic PSW610J's...
I'm broke and i don't want my son deaf before he's 2 haha
My alt charges my kinetiks at 15.2, no issues
1969 Chevy Chevelle
20/22" staggered Bonspeed Huntingtons wrapped in Nitto INVO's
Mechman 250amp cs144 alt w/AVBM
Kinetik 1800 main battery/Kinetik 2400 in the trunk
Pioneer AVH-3200dvd Headunit
(2) sets of Hybrid Audio Technologies Imagine components up front
(2) DD 3512's d4 coils
Sundown sax100.4 component amp
Sundown saz-3000d subwoofer amp
5ft^3 box tuned to 34hz
MY BUILD
Well, it only puts out 10 amps on the fastest charge and when I talked to Mechman when my alt died they told me that lower sitting batteries can hurt alternators. So I want to make sure that im not killing my alt, I can't really afford to send it back because my old alt doesn't fit. I'm trying to get these batteries to the proper sitting voltage so I'm not jeopordizing any of my equipment.
Lower sitting batteries? you mean a drained? Cause if that's the case then i haven't heard of that (maybe i should look into that.... but if you want to charge your batt's with that charger you could invest in a 1.2 ohm resistor that's rated for 120 watts.... I haven't found a resistor that big yet though trying to find one lol
edit...i have a feeling my math may be a tad wrong there....
Edited by d3dreaper
It won't charge at 15.5 unless your batts are flat as the amps come up the volts go down. yea a huge bank of resisors lol I've got a few thousand but I have a feeling that wouldn't be enough. Put a dmm on it the hook up your charger and watch the voltage if it gets up over 15.2 or so un hook it but my alt in my truck starts out at 14.7 so .5 volts more isn't extreme by any means.
Edit
If your batts are flat and you slam on your system it puts a huge load on the alt and cause avoidable strain on you electrical, not just your alt either you amps like good power most will get mad if you run them on fluctuating electrical system
Edited by EBW
Kenwood KIV-BT900
Front Stage
RF 400-4 Runs off dedicated 4 awg ofc
RE 6.5 125.5.
Lanzar Max Pro 6.5
Boston S60 6.5 components
Rear
Soundstream BX-15
4x Sundown SA8 v1.5
Crescendo BC3500D
2.4 net 28hz
4 runs of 0 gauge
Big 3
HC2400
700ca up front
Singer 350 Amp Alt
No deadener :/
Scytek Galaxy Alarm
Hell you only need to do 10amps for 20 min per battery
Thanks for all the help guys! Well, I'll try putting my redtop that sits at 12.2-12.3 on the charger, but what got me as weird was I put my brand new D1200 on it and t still went up to 15.5...
I'll take ray's advice though, hopefully it wont hit the batt's too hard.
  • Who's Online   1 Member, 0 Anonymous, 1519 Guests (See full list)
