People don't generally consider solid copper rod as a "wire", so in terms of "wire" strand count only affects flexibility.
As one had mentioned before, Surface area and Resistance matters most. In a solid copper rod, you will get less resistance, but you can't run it entirely through a car. it just isn't practical.
Personally, less wire strand is better for resistance purposes, but don't excuse bad quality for low strand count. Some manufacturers way OVER RATE their wire size buy having thicker jackets. The strand count may be high, but the actual wire thickness would be overall low.
If I could do it, I would run 1/0 solid through my car, but no car audio manufacturers make it, and the wire you can purchase in that size is designed for home/commercial/industrial electrical use, and doesn't have a jacket designed to sustain the harsh external environments an engine bay and undercarriage see on a daily basis.
Chris - "The Apprentice" - Pandora's Box Customs
1994 Ford Explorer - "Midnight" - 4.0L SOHC
SoundStream PCX-1000D & Kicker S12L5
couldn't you buy an insulated tube to put it in like the ones you run electricty through the ground with?
More strands equals more flexibility, that is all. When dealing with DC the number of strands doesn't really matter.
x2
ive seen copper rods for speaker connections on inverted subs. it looked bad ass.
Edited by skittlesRgood
The berillium(spelling?) bmw uses solid copper bars for its sub wires, looks bad ass and im sure serves somewhat of a purpose :)
Edited by lifted_silverado
Everythings in the attic or garage since the truck was sold last year. New build should be coming soon in a dodge cummins smile.gif
I assume you could, but again, solid 1/0 practically requires a pipe bender to get it around corners. It just isn't practical to run it long distances through the interior of a car. I was trying out a spool of it in Home Depot one day as I was pretty curious about the same thing. Home Depot had it for just over $1/ft, so I was playing with on the spool. I couldn't even get it do a 90 degree bend with my hands. There was no way I was going to take the time to try and really run it through a firewall and under some carpet.
could you run it in combo with the reg 0ga we use for the bends u need?
edit: or would that defeat the purpose?
Edited by Jd1102
its all about surface area my friends
I have to agree but also if its soldered.
Jensen head unit (junk to start) cadence 5.25 dash re tweets Candence ultra drive amp(mids+highs) rockford fosgate 75hd RESX18D2 X4 subs wired to 1.3 final
REBUILDING AS WE SPEAK
i have a question is solder bad for connections bc its not as conductive as copper right?
