bdog Posted September 10, 2011 Report Posted September 10, 2011 6 month old fi bl 12 just stopped working so i pulled it out and tested the coils and one coil reads nothing and there is a small cracks above the tinsel leads . how does this happen? i set the ssf so the subs would not bottom out and only fed it a AQ1200 . could it be i only gave it one week break in time? box is 2.1cf tuned to 32hz with 32.6" or port area . im just so confused coils look nice and bright/shiny .Any ideas of what i did wrong? Quote REP
Maticus Posted September 10, 2011 Report Posted September 10, 2011 Cracks above the tinsel leads, caused from when the tinsels heated up too much from the amp sending clipped power and the burn made a weak spot causing it to rip with excessive movement? Quote
bdog Posted September 10, 2011 Author Report Posted September 10, 2011 if it was getting that hot wouldn't my coils look dark not brand new like they do ? Quote REP
Maticus Posted September 10, 2011 Report Posted September 10, 2011 (edited) With clipping those leads probably would have went before the coil, considering they are the old style flying round leads, correct? Edited September 10, 2011 by Maticus Quote
01VWGREENMACHINE Posted September 10, 2011 Report Posted September 10, 2011 im still a little new but sounds like the sub was under powered which causes clipping?? Quote http://www.stevemead...f-system-build/ 2001 VW GTI with a 1.8T motor BIG 3 Pioneer AVH-4200DVD DOUBLE DIN HEAD UNIT 6 - 4 VOLT PREOUTS RF T1500-BDCP (running at 2 ohm) RF T400.4 RF T1 D212 x2 (in ported box) RF 1/0 TO 4 GAUGE distribution block x 2 all stinger wires 200a alternator (SINGER ALT) RF T2652-S (6.5 MID BASS AND 1" TWEETS in front and rear) KINETIC HC 800 BATTERY (Front) KINETIC HC 1200 BATTERY (BACK) 120ft of 1/0 stinger blue and clear matt 20ft of 4 gauge stinger blue and clear matt 30ft of 8 gauge stinger blue and clear matt 100ft of 12 gauge stinger speaker wire black
Maticus Posted September 10, 2011 Report Posted September 10, 2011 im still a little new but sounds like the sub was under powered which causes clipping?? No, Clipping is caused by too much gain, or songs that just naturally clip. Clipping is when a round wave ends up getting squared off at the crest and the trough of a wave. You can never damage a woofer by under-powering it with a clean signal. Quote
bdog Posted September 10, 2011 Author Report Posted September 10, 2011 well it has been clipped and won 1st @ 2 slp shows and took 1st place canada nation wide this might of done it lol Quote REP
deathcards Posted September 10, 2011 Report Posted September 10, 2011 im still a little new but sounds like the sub was under powered which causes clipping?? my sub has about 300 going to it out of 750 i think its because of the speaker terminals on the box but anyways back to the point my sub has been going for about 2 years and still going strong Quote skar sk2500.1 0 gauge power and ground kunukonceptz alpine HUvxi65 components on BA gt-275new build log -> http://www.stevemeadedesigns.com/board/topic/150642-project-d-kon-deathcards-build-log/#entry2148821 2 x-15 sundowns singer alt, odyssey bat, and maxwell ultra caps
01VWGREENMACHINE Posted September 10, 2011 Report Posted September 10, 2011 im still a little new but sounds like the sub was under powered which causes clipping?? No, Clipping is caused by too much gain, or songs that just naturally clip. Clipping is when a round wave ends up getting squared off at the crest and the trough of a wave. You can never damage a woofer by under-powering it with a clean signal. thanks for the info still learning alot about this stuff hehe. i was told by a local shop if you under power a woofer it will cause unwanted heating and clipping. but i was wondering since i see alot of people under powering there subs for the time being till they can afford new amps so it makes sense!! hehe thanks! again Quote http://www.stevemead...f-system-build/ 2001 VW GTI with a 1.8T motor BIG 3 Pioneer AVH-4200DVD DOUBLE DIN HEAD UNIT 6 - 4 VOLT PREOUTS RF T1500-BDCP (running at 2 ohm) RF T400.4 RF T1 D212 x2 (in ported box) RF 1/0 TO 4 GAUGE distribution block x 2 all stinger wires 200a alternator (SINGER ALT) RF T2652-S (6.5 MID BASS AND 1" TWEETS in front and rear) KINETIC HC 800 BATTERY (Front) KINETIC HC 1200 BATTERY (BACK) 120ft of 1/0 stinger blue and clear matt 20ft of 4 gauge stinger blue and clear matt 30ft of 8 gauge stinger blue and clear matt 100ft of 12 gauge stinger speaker wire black
bkolfo4 Posted September 11, 2011 Report Posted September 11, 2011 If underpowering damaged subs, you would have to listen to them at full volume all the time or they would get damaged. Had a kid call me and let me know that crutchfield said that logic is not true. "A 600 watt amp outputs 600 watts all the time. It is just the voltage that changes." Quote Current system: 1997 Blazer - (4) Customer Fi NEO subs with (8) American Bass Elite 2800.1s Previous systems: 2000 Suburban - (4) BTL 15's and (4) IA 40.1's = 157.7 dB at 37 Hz. 1992 Astro Van - (6) BTL 15's and (6) IA 40.1's = 159.7 dB at 43 Hz.
