What tools do you need to correctly install an alarm?
I have installed a alarm myself, so this is what i would do
Solder
Soldering iron
Heat shrink/ Electrical tape
Wire cutters/ strippers
Various screw drivers and you might need a socket set depending on your car
Also self tapping screws will help mount the shock sensor and Brain
Thats pretty much the basics, Do yourself a favor and solder ALL your connections, avoid T-Taps.
You DO NOT want your connections coming loose on something thats supposed to help protect your car.
ive done like 30-40 of these alarms/remotestarts, and this list is perfect, get good quality electrical tape, I use 3m cold weather stuff, stays on in cold weather and sticks amazinly, also you need to have a ddm, its not even an option, you need it! also before you just go into the car with it, cut out any wires you dont need, get the brain with all the wires setup, with the wires you need going to certain areas grouped together, trust me, makes the job 500% easier!!! :D worth it for sure
I have always cut my wires to legth sense my first instal, Makes it way easier then trying to hide a rats nest.
What exactly is a ddm? I have never heard that term before.
Digital Multimeter, You can pick them up just about anywhere, Autozone has 2 decent models
http://www.autozone....fier=64471_0_0_
The one i use
http://www.autozone....fier=64472_0_0_
The one my buddy has, This one has a built in battery test lights to let you know if your starting battery is in good standing.
yea, I do that to, I get them grouped going each way, mount the brain to a good spot, route the wires, cut to length, and solder them in, clean install, and is much quicker :D
2006 Mazda3 Hatchback Black 5 Spd Manual
Pioneer 4300DVD
2 Sundown SA-12 (34hz Tune, 3.22 cubes, 14.5 inches per cube, Triple Baffle)
Kicker 10ZX2500.1 (2845 RMS) Sub Amp
Kicker 11ZX650.4 (705 RMS) Mid Amp -- (3 Amps)
Kicker KQ3 Active Crossover
Kicker KQ30 Equalizer
Kicker 09QS60.2 Components (Woven Carbon Cones)
Kicker 09QS65.2 Components (Woven Carbon Cones) - (3 Sets)
2/0 Gauge Electron Beam Technologies (3 Runs, 2 +, 1 -)
1/0 Gauge KNU Kollasal Flex (1 Run for -)
300 Ft Kicker X-Series 16 Gauge Speaker Wire
XS Power D3400 (Rear)
XS Power D3100 (Front)
Singer Externally Regulated Alternator (Being Built)
+ The Love for Car Audio and BASS <3
UBL Build Log <------- Click Here-------> Normal Build Log (For Comments)
Well I think i have everything now to correctly do this install once my truck gets here.I have about 3 weeks left before it reaches Italian soil.I will post pictures of everything and a list so you guys can let me know if I missed anything.Again thanks for all your help and input.
Vehicle
2007 Chevrolet Avalanche(Co-Co)
DNX9980HD
6 Team Fi 15's(King Edition)
3 DC 9k's
8 Nendo PWX 8's
4 Custom Steg 4" Super Tweeters
1 DC Audio 175.4
1 DC Audio 90.4
Rockford 360.3
3 DC Power 370xp Alts(Externally regulated)
21 D1600's
2 D4800's
All SMD RCA's
AudioTechnix Deadner
Viper Alarm
My YouTube- http://www.youtube.c...NG?feature=mhee
Link to buildlog- http://www.stevemead...4-15s-2-dc-9ks/
Link to UBL- http://www.stevemeadedesigns.com/board/topic/165059-ublkings-avalanchecoco-new-build-starting8-king-edition-15-team-fis-in-a-wallyes-a-wall/
Solder
Soldering iron
x2 100% solder all connections
1995 Honda passport 3.2 4x4 Frankenstein on a budget
ballistics sound deader (roof only so far)
kenwood mp3 usb
audio control 3 (upgrading)
hifonics mx-3
3 sets of massive px5 5.25s
3 sets of massive tweets
phonix gold 5.25 componets
x2 massive nx4 nano 200x4 mids
sony xplod 600x4 watt high's
2 Fi bl fully loaded box walled @31ish hz
13.2 cube box/wall
massive DB8000
Excessive amaperge 250 amp alt wir extrnl regulator
daul runs of xs power xpflex 0 gauge
big 3
raptor 0 gauge power/ground wire full run
suriken 45 amp hour x3 shriken bt-120 batts,interstate 1100CA semi batt
scytek galaxy 2way alarm
still upgradeing!
you will need the alarm,shock sneser/s black tape,solder,soldering gun,shrink wrap,zip ties,cutters,instructoins,12volt.com,securtey bypass,relay/s screw drivers,10 gauger to run to batt banks +under hood,test light,muliti meter and lot of spare time if this is ur 1st....i may be forgetting stuff im sure others will pipe in...GL i would take it to a pro myself
kenwood mp3 usb
hifonics mx-3
13.2 cube box/wall
massive DB8000
big 3
still upgradeing!
Yeah Im in the process of buying a lil beater car so I can put the truck down for awhile so I can take my time to do it.I think i have everything you listed and that everyone has said so far. Once I start I will make a new thread for the install.Thanks for your input.
Vehicle
DNX9980HD
3 DC 9k's
8 Nendo PWX 8's
1 DC Audio 175.4
1 DC Audio 90.4
Rockford 360.3
21 D1600's
2 D4800's
All SMD RCA's
Viper Alarm
  • 4 weeks later...
So now that I have my vehicle I decided that in my spare time I would just mark off all the wires I need for the alarm install.I noticed that the Xpresskit PKALL doesn't state that its compatible with my truck. Is there something I'm missing or do I need to order a different kit? I want whatever is the easiest to install.So hopefully no keys needed and no other items required to program.Thanks in advance
Vehicle
DNX9980HD
3 DC 9k's
8 Nendo PWX 8's
1 DC Audio 175.4
1 DC Audio 90.4
Rockford 360.3
21 D1600's
2 D4800's
All SMD RCA's
Viper Alarm
I keep seeing ddm in this thread... I thought it was dmm.?
Op hopefully you find out what you need to know. Free bump. :)
Firgured I'd throw this out there for ya it's pretty helpful for the basic stuff
http://www.commandocaralarms.com/info_installing_a_car_alarm.asp
145.9@40hz
145.3@34hz
big 3
X2 group 34
Deka Group 31
All 0/1 awg jl meta wire
Alpine CDA 7894
Orion HCCA D5000
2 AQ HDC312's
Crunch gpv1100.2 (for 6.5"s only)
AQ pro audio 6.5" - 3 sets
AQ supertweeters - 2 sets
2000 Slamry
Yeah I actually printed out some stuff from that site recently for this install and yeah the DDM was throwing me off and I had no clue what it meant.You would think Digital Multimeter would be DMM instead of DDM LoL
Vehicle
DNX9980HD
3 DC 9k's
8 Nendo PWX 8's
1 DC Audio 175.4
1 DC Audio 90.4
Rockford 360.3
21 D1600's
2 D4800's
All SMD RCA's
Viper Alarm
Lulz.. It is DMM
145.9@40hz
145.3@34hz
big 3
X2 group 34
Deka Group 31
Alpine CDA 7894
Orion HCCA D5000
2 AQ HDC312's
2000 Slamry
Double post fail...:(
145.9@40hz
145.3@34hz
big 3
X2 group 34
Deka Group 31
Alpine CDA 7894
Orion HCCA D5000
2 AQ HDC312's
2000 Slamry
