i have two kicker comps and they are 07 12inch.
If i was to get a hifonics or kicker amp that producees 600watts RMS or 450 watts RMS at 4 ohms, and each speaker get the according wattage, would i blow these things? i have heard that kickers take one HELL of a beating.................
If the gain is set properly, they should take that power nicely.
do you mean like, the gains on the amp and what knot so no distortion?
And which amp should i get?
The Kicker ZX 450.2 or the Hifonics BRUTUS BRZ1700.1 amp?
And my kickers are wired to a 4ohm load......
Do you have two 4ohm single voice could subs?
so far...
HU- pioneer DEH-P59001B
Amp- crescendo BC2000D
Wire- 1/0 awg welding lead
Electric- Big 3 ^same wire
Subs- 2 Obsidian Audio 12 d4's
Box 4ft^3 ported at 33hz. designed by Ram-Designs
read the fist post.
2 2007 kicker comps, 12inch single voice coil. both are wired together so that they present the amp with a 4ohm load....
I did read the first post, but since you are asking this noobish question I have to assume you don't know how to match impedances either, so I just want to make sure you get the power at the right impedance. So in other words you have 2 8ohm svc subs...
so far...
read the fist post.
or 2 2ohm subs wired in series. see im not dumb. lol and chill, its a no bigie. we all friends here....
Well if you had 2 2ohm subs it would be dumb to look for an amp that makes power at 4ohms, it'd be much easier and cheaper to get power at 1ohm
so far...
A kicker 750.1 would go nicely. I wouldn't overpower those subs too much
so far...
  • Who's Online   0 Members, 0 Anonymous, 893 Guests (See full list)
