i need some advice on what to ground to in my 2000 jeep cherokee. my seat dosent have brackets, it just has two hinges and im not sure how they attach. i dont have enough wire to reach my spare tire holder, and i dont think there is really anything else besides the sheet metal on the body. would it be a good enough to ground to the body?
JEEP BUILD PROJECT ANTIBLING.2000 jeep Cherokee.HEADUNITAlpine Cda-9886SUBSTAGE1 acendent 18" audio mayhem motor with a TI basket and tantric parts1 prototype DAT hellfire 1000.1HIGHSStockELECTRICALdb link 0 gaugeKnuconceptz Kolossus 4 gauge1 xs power d3400 under hoodBig 3 upgradeold fourwheeler build
The only way to delete your SMD account is for you crawl to steve meades door step on your knees and pleade for his forgiveness and acceptance to be released...He will either grant your wishes.....or choke you with a large piece of 0 gauge and electrocute you by hooking up a solid gold DC 12k at 0.000001 ohm and 10000 volts to your eye sockets and blow your head apart
You guys act like you have never clogged a toilet and ran around the bathroom frantically hoping it don't overflow.
Don't ground to a seat bracket. I only ground to the frame.
under construction
I hate People with crappy primered cars rolling on hubcaps that are louder then me.
u hate c-fizzy?
How much power is your system pulling? I'd try to get enough wire to make it to a good clean frame ground, but if not a sanded off body/chassis ground would work.
Then just make sure your big 3 is done and a body/chassis ground is to the engine block under the hood. :good:
1997 Chevrolet Silverado Extended Cab, 350 Vortec
Things to come at some point...
Build Log: http://www.stevemead...2200ds-133-ohm/
im only going to be running a 600 watt 6 channel for a while. i haven't done the big three yet but i hope i can in about a month or two. i don't think i will have enough to go to my frame seeing as i only have 3 feet of wire to work with.
now the challenge will be finding a spot that isnt directly above my gas tank
Edited by bass_stalker
Well a 600 watt 6 channel sounds to me like 100-200 rms. Which isn't pulling much at all. So just find a place on the chassis, sand it off and tap a bolt/nut or screw.
With that much power you don't really need to do big 3, but it's always there for future builds/upgrades.
yeah. it isnt much power. i just wanna do everything right so i dont damage my amp, and so i don't constantly have problems with it. i still wanna do the big three eventually. like you said its already done whenever i decide to upgrade, plus it'll get rid of the old dingy fades wires
If you can ground to the engine block itself do so. If not, frame. And make sure big 3 is done either way...good luck :good:
Xterra * 69 Camaro * Audi S5
36 Ford * 51 Mercury
looking for wire sponsor :)
www.flyracing.com
for the big three or for the amp? i was asking about the amp ground. yeah for the big three i know 1 goes to the engine from the battery and one goes from the frame to the battery. i don't really like the way the battery is grounded to the fender currently
I always run the wire through the sheet metal and right to the frame of the car :D
2006 Mazda3 Hatchback Black 5 Spd Manual
Pioneer 4300DVD
2 Sundown SA-12 (34hz Tune, 3.22 cubes, 14.5 inches per cube, Triple Baffle)
Kicker 10ZX2500.1 (2845 RMS) Sub Amp
Kicker 11ZX650.4 (705 RMS) Mid Amp -- (3 Amps)
Kicker KQ3 Active Crossover
Kicker KQ30 Equalizer
Kicker 09QS60.2 Components (Woven Carbon Cones)
Kicker 09QS65.2 Components (Woven Carbon Cones) - (3 Sets)
2/0 Gauge Electron Beam Technologies (3 Runs, 2 +, 1 -)
1/0 Gauge KNU Kollasal Flex (1 Run for -)
300 Ft Kicker X-Series 16 Gauge Speaker Wire
XS Power D3400 (Rear)
XS Power D3100 (Front)
Singer Externally Regulated Alternator (Being Built)
+ The Love for Car Audio and BASS <3
UBL Build Log <------- Click Here-------> Normal Build Log (For Comments)
Are you using a 2nd battery? If you have a second or more battery i was saying ground the extra batteries to the engine itself, or frame if you cant do it to the engine. As far as just the amp, frame would probably be the best. Your electrical system grounds thru the engine to the drive train. So the engine itself is your best source for ground. However always do the big three. And one good ground is better than a bunch of bad ones.
www.flyracing.com
