well i will be reciving my second 3500d1, tuesday and i was wondering how low can the amp see before going into protect? i dont wanna make my amps into paperweights and fuck them all up, also anybody clamp there yet?
thanks on anyone that replys to my question
o and also my electrical is
2d3100
1d3400
mechman270alt
big3done
CAR
-2005 Ford Mustang (Legand Lime)
H/U
-Pioneer avh 3200dvd
Amps
2 AQ 3500d.1s strapped 1ohm daily .25burps
1Sundown Audio 100.4
1 Sundown Audio 125.2
Subs
4 AQ HDC'4s 12's
Mids and highs
4 Sundown Neo Pro 8s
2 AQ Super Tweeters
Electronical
Mechman 270 unit
1 D3400
2 D3100's
WALLED!
Well I mean, they're stable at 2 ohms strapped. So 1 ohm per amp. And with that electrical, I wouldn't run them any lower than that. Hell, one of those at 1 ohm pulls 380 amps. So you're looking at around 800 amps.
under construction
I hate People with crappy primered cars rolling on hubcaps that are louder then me.
u hate c-fizzy?
dam! so now im limited because of my coils i have .7 coils on my woofers
best i can do is just run them in series then huh =(
Edited by KnockinthaStreetzof608
CAR
H/U
Amps
Subs
4 AQ HDC'4s 12's
Mids and highs
2 AQ Super Tweeters
Electronical
Mechman 270 unit
1 D3400
2 D3100's
WALLED!
Perfect then. Run your amps at 4 ohms strapped. You're still getting ~2600 per woofer and it's not a huge strain on your electrical.
What moofers?
under construction
u hate c-fizzy?
dc audio XL
CAR
H/U
Amps
Subs
4 AQ HDC'4s 12's
Mids and highs
2 AQ Super Tweeters
Electronical
Mechman 270 unit
1 D3400
2 D3100's
WALLED!
4 ohms strapped should be fine for them. Like I said, you're still getting 2600 before rise.
under construction
u hate c-fizzy?
Were u get 4 ohms at c fizzy ? Lol how many subs?
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
The general consensus is, if you have to ask - don't.
THat being said. those 2 amps strapped at anything under rated are going to eat your electrical alive and spit out charred remnants of what used to be your coils and amps.
The aq 3500.1 is very simalar if not the same board as my dd m4s. I run mine at .7 strapped daily but I have the electrical to back it up I don't recommend it unless you know what your doing. But you should be ok at 1.4 strapped
TEAM DC AUDIO
PREAMP:arcaudio
SUB AMP: 2-dc7.5s
BATTERIES:6-d1400s
i have 2 woofers, so you think it will be fine wired series/parallel?
well in my electrical im kinda limited but i do have 4 more 3100's coming hopfully by saturday to make a total of 6 d3100's on the alts i cant do much about that there is no way to add another alternator which i really wanted to do, and in all honestly it burns up my coils o well idc ill just recone them and call it a lesson learned, no skin off my back :shrug:
well i should be getting them amp tuesday so i have till saturday to do some testing, soo what it likes and doesnt like, i just wanted to hear anyone running strapped aq3500d1 and see what they experienced so i atleast had some kind of feedback not just from what the manual says
CAR
H/U
Amps
Subs
4 AQ HDC'4s 12's
Mids and highs
2 AQ Super Tweeters
Electronical
Mechman 270 unit
1 D3400
2 D3100's
WALLED!
