looking for advice tips and tricks for painting your own car. not talking spray paint i have a few guns at my disposal wanting to do a base red ,clear with heavy black flake so looking for all the advice i can get.
I picked up an MTX Sw1212 powered subwoofer today. This thing sounds amazing. 130 watts, 12" woofer with a passive 12" woofer tuned to 27 hz. Moving the pictures on the walls and my girl got wet from the bass when i showed her haha. Tonight should be good haha.
ive tried but really hard to do. make sure you sand down every piece of your car and every single edge because thats where to peeling will start first.
12- DC Audio m2Lvl3 12's1- Hertz HSK3 way2- DC5K's2- ZX350.42- Stinger SP1500D batteries in rear3- runs of 1/0ga. to the rearTeam DC Audiodc-banner.jpgdcsoundlab.com
Quality is all in how you take pictures ;) I have plenty of projects that look WAY better on camera then in person :D
crazy to fit so many in so little. Reminds me of some of the porns I've seen?
Prep, prep, and prep. And when you're done prepping, prep some more. Do not cut any corners in the beginning stages. What type of guns?
im pretty sure theres 2-3 eclipse and a a couple craftsman guns the eclipse are older
THIS
Lots of prep. When the paint goes on, any laziness or cut corners will come out sooner or later. make sure everything is sanded and looks nice before you even think of painting. Also, fix minor dents. might seen insanely tedious, but the look just improves dramatically. I guess I don't need to tell you about how to apply the paint with the gun.
prep would consist of fixing any dents/ rust and making the place to be painted as smooth as possible right? whats some advice for getting rid of small dents or small places were rust has eaten threw a panel. like in my rear 1/4 panel a spot almost the size of 50 cent piece has been eaten away. with this car new metal isnt really an option as they dont make replacement panels for that part so what would u guys advice i do to stop the rust from coming back ive cleaned it away the best i could with a brush grinder sealed it with primer sealer then bondo to make it flat and flush so then it looks alright for a few months then starts to come back.
ive done a Lerner course on spray painting/panel beating course.
things ive learnt is prep everything!
dont use cheep guns they'll end up spitting and fuck up the whole thing.
use the same brand of paint as your primer/clear otherwise it might start just flaking off.
mask out properly with perfect lines,doesn't matter if you have to try masking the same thing 5 times,as long as its perfect.
defiantly do on a day absolutely no wind ,if your doing in a shed clean all the dust out.
spray form top to bottom.
dont spray from one side then stop then the other then stop,try keep the gun going on air so it doesn't spit.
ill try thing of anything else...
Henry Ford once received a letter from a depression-era bank robber responsible for the deaths of several law enforcement officers, killed in their attempt to stop him as he fled the crime scene. In his letter, he thanked Mr. Ford for making his Model A Ford such a good getaway car.
just cut it out and weld a new piece in the rust should stop at the weld.
