subs burning and amp on fire
my brother taught me to do it. on a crunch amp i got from him, the board was mounted to the metal case (he took it apart and did it cuz it was supposed to help cool) and it never had a good ground, so i grounded case and worked fine from then on. so since then, ive done to all my amps.
all amps are mounted to the case that its inside. never ground an amp like that, ever. use only the terminals that are actually on the amp itself.
i do stupid things when i dont understand what happened. thats why i sprayed water on em. i wanted to see how hot they really were since i have a burn on my fingertips now.
Lucky Durango
Sony hu
4 croosfire 6.5mids
crossfire 600.1 mono amp
American bass 1280.4 mids and highs amp
aq hdc3 12
2.4 cube net box, tuned to 34 and 14.4 inches of port per cube
OK. now i know. thanks. i also want to know how to run multiple batteries when i upgrade my alt. i run from positive of al to both batts right? then where do i run the 2nd ground?just make a new one or?
Lucky Durango
Sony hu
4 croosfire 6.5mids
aq hdc3 12
Yeah the 2nd ground is definately a problem! The electricity has to take a specific route through the board to function, you grounding the current through the amp case is going to completely fuck that route up. It might even shock your ass or start your car on fire! Any other special tricks in your wiring man? I'm worried now
so far...
HU- pioneer DEH-P59001B
Amp- crescendo BC2000D
Wire- 1/0 awg welding lead
Electric- Big 3 ^same wire
Subs- 2 Obsidian Audio 12 d4's
Box 4ft^3 ported at 33hz. designed by Ram-Designs
Sounds like you really need to be careful and read some more before you just start adding wires....
lower tuning is just hard. I was surprised how loud 145 sounds at 35hz, and how quiet 145 sounds at 50hz.
-= 2005 Tahoe LT =-Head unit: Pioneer AVH-X5500BHSSource: iPad Mini in dash
Subs: 2 T1 12's
Sub Amp: T1500-1bdCPWire: Rockford Fosgate 1/0 awgSignal Cable: MonsterFronts:Stock Bose for now:)Rears: Stock Bose for now:)MIds/High amp: Stock Bose for now:)
2005 Tahoe Build Log: http://www.stevemeadedesigns.com/board/topic/172529-2005-tahoe-my-17th-vehicle/
2001 Monte Build Log: http://www.stevemeadedesigns.com/board/topic/160030-2001-monte-carlo-my-16th-car-lol/page-2#entry25309381997 Tahoe Build Log: http://www.stevemead...oe-6-15-rf-15s/2001 Impala Build Log: http://www.stevemead...katzkin-inside/SMDSig3-26-12.jpg
front battery + to rear battery +. rear battery - to chassis (sanded down to bare metal, like any ground should be). big 3 should be done also
no, just that one. other than that its normal. can second ground cause car noise to run through speakers, say a blinker noise when amps running and cars on?
Lucky Durango
Sony hu
4 croosfire 6.5mids
aq hdc3 12
X2. Car-B-Que.... :popcorn:
Subs: 2 T1 12's
i never had a problem with it before and i learned most from my bro and i just recently found this site and the understanding that you really can find anything on the internet.
Lucky Durango
Sony hu
4 croosfire 6.5mids
aq hdc3 12
couldn't tell you because ive never seen this situation before. but im sure its not helping your situation one bit. your amp isnt that great a brand also, thats probably partly why it caught on fire
  • Who's Online   0 Members, 0 Anonymous, 2030 Guests (See full list)
