So....i finally statret to build my car audio system..
and here and there i bought some batteries... and some 0 gauge...
the problem is the subs...
i am going to order 2 15...but dont know which one to order
the subs will take EACH from 500 - 750wRMS, so the range power for both will be around 1000- 1500wRMS...
the subs will be...
well i need oppinions and some help with this...
the box is going to be at max at 6 cubic foot...maybe 7 at MAX
subs would be...
A:)2 re audio SE 15
or
B:)2 re audio SX 15
I was for the SE model FIRST, but the SXs can take much more power....so could be ANYthing wrong if I power the subwoofer that is rated at 1000wRMS, with the power of 600wRMS???
2010 Chevrolet Cruze
Radio --- pioneer mvh-200vbt
Front/back --- alpine type s 6.5"
Sub Control --- Pac LC1
Sub Amp --- GZPA 1.4K
Sub --- GZNW 15XSPL D1
Battery - GZBP 12.2500X
shouldnt be. you cant damage it from under powering it. not too sure how under powering affects the sound though.
JEEP BUILD PROJECT ANTIBLING.2000 jeep Cherokee.HEADUNITAlpine Cda-9886SUBSTAGE1 acendent 18" audio mayhem motor with a TI basket and tantric parts1 prototype DAT hellfire 1000.1HIGHSStockELECTRICALdb link 0 gaugeKnuconceptz Kolossus 4 gauge1 xs power d3400 under hoodBig 3 upgradeold fourwheeler build
The only way to delete your SMD account is for you crawl to steve meades door step on your knees and pleade for his forgiveness and acceptance to be released...He will either grant your wishes.....or choke you with a large piece of 0 gauge and electrocute you by hooking up a solid gold DC 12k at 0.000001 ohm and 10000 volts to your eye sockets and blow your head apart
You guys act like you have never clogged a toilet and ran around the bathroom frantically hoping it don't overflow.
Are you set on RE?
Sounds like a good fit for the AA Chaos. . .
Current system:
1997 Blazer - (4) Customer Fi NEO subs with (8) American Bass Elite 2800.1s
Previous systems:
2000 Suburban - (4) BTL 15's and (4) IA 40.1's = 157.7 dB at 37 Hz.
1992 Astro Van - (6) BTL 15's and (6) IA 40.1's = 159.7 dB at 43 Hz.
well i know if i chose the SE would be in the right power range...but still...the SX can take that much more power...and if they take like 600rms at piece...... would do any harm?
The only thing I can think of that could hurt em if you are underpowering is clipping.
2001 chevy cavalier
Rebuild in progress
what happens when your CD player skips and you accidentally drop a 22 hz sine bomb at an unholy volume on 7-8 year old subs? Mechanical failure floppy sub knockage on at least 2.
well...as i see the level 6 is compared to a lamborghini.....but a corvette?
i was thinking more like a chevy volt. its cute and new and "hip", but i would just rather stick my dick in a blender.........
clipping??
with songs??
or with to less power??
You can't clip a sub by underpowering it. Unless you have a "1000" watt amp with the gain maxed out.
under construction
I hate People with crappy primered cars rolling on hubcaps that are louder then me.
u hate c-fizzy?
Clipping is when you square off a sine wave, which is sending your subs dirty power. The only two ways to tell if you're clipping is an o scope or dd-1. Just because a woofer is rated at a certain rms rating, doesn't mean you have to have that amount of power.
2001 chevy cavalier
Rebuild in progress
my gain is almost allways at minimal
oh...and the amp would be an Ground Zero 1200DX...it gives 1440wRMS of clean power at 13,8V or 1260wRMS at 12,4V
Edited by gally
the only reason WHY i am asking this question is because i would like to have these 2 subs for a long period of time...and then, maybe for like a year later i would change the amplifier that would properly power the Sx....
or i wouls just stay at the SE line....but then still...it would be overpowering...
Edited by gally
