IDK man, id try to see what your impedance rise is if you can because that will help us all out to see what your impedance load is for different frequencies.
2004 GMC Envoy1 XS power S3400 batt under the hood and 4 XS Power D3100's battery installed in the rear by the amps0 gauge power wire from front to backAlpine iva-w205 touchscreen dvd/cd/mp3/ipod/am/fm/gps headunitSundown Audio SAX-200.4 amp for my mids and highs8 gauge speaker wire from amp to woofer270 amp Mechman AltRockford Fosgate T1652-s component speakersRockford Fosgate 3Sixty.2 sound processorRca's from Rockford Fosgate and Monster Cable14 gauge speaker wire for the mids and highs1 18" Ascendant Audio SMD Dual 1 ohm with custom Black & Blue carbon fiber and hand signed dustcapBox: 5.66 cubic feet net volume box tuned to 30.13Hz with 1.5" wide wooden dowels and 1.5" thick baffle1 DC Audio 5.0k amp wired to .5 ohms nominal with an imp rise of 1.35 ohms for the single AA SMD 18"Future Vision 8000k 50w bi-xenon projector HID's with 4300k 35w fog lightsLink to my build: Buildupdates/progress
I would assume its pretty high since theres 12 subs, this all started after switching decks, im back to original and still have same problem
my only other thougjt is the rca im using to strap amps is no good
1998 gmc extd cab
12 crossfire C710s
4 SAZ-4500s
3 Singer 400A alts
buncha mids/highs
Team Asshole
The RCA im using is just an olde rca i use.one side of since i cant get single short rcas localy
1998 gmc extd cab
12 crossfire C710s
4 SAZ-4500s
3 Singer 400A alts
buncha mids/highs
Team Asshole
It could be but that still wouldnt make any sense. I was screwing around with my old amps strapped and i disconnect the master/slave rca and it still produced bass but it was half the power since one amp was taking the job instead of sharing the load with both amps but it still worked and didnt throw itself into protect. Do you have an oscilloscope? If you do id see if you can try to burp it and look at your scope to see if when you get to the point where it protects if it has a dc voltage output or something because my amp has dc offset and yours MAY but idk for sure.
The manual says something about that, but still doent make sense...it worked fine, till i tried the kenwood, and its been down hill since
1998 gmc extd cab
12 crossfire C710s
4 SAZ-4500s
3 Singer 400A alts
buncha mids/highs
Team Asshole
Im gunna try a new strapping rca yes i reset gains with new deck, Im back to original deck now tho.and still have issues notvas bad tho
1998 gmc extd cab
12 crossfire C710s
4 SAZ-4500s
3 Singer 400A alts
buncha mids/highs
Team Asshole
i figured out my protect problem, its from not enough box rise, i clammped the amps, and starting at .4 per amp ( strapped at . 8 ) i rose to 2 ohm strapped ( 1 ohm per amp) and made... 11400rms!! so the amps protect from being wired to low, its ok on a slow. roll burp but not very great for music
1998 gmc extd cab
12 crossfire C710s
4 SAZ-4500s
3 Singer 400A alts
buncha mids/highs
Team Asshole
Sweet. Good job finding that out. I honestly thought it was odd that the radio swap would cause it to protect. Also watch ur imp rise when the woofer breaks in. My imp dropped like .3-.4 ohms from what it used to be when I first got my system in.
