HPF makes my woofer very quiet
nitwimp
Bass cant move from -6. Isn't the bass setting on most decks(at least everyone ive seen) control the door speakers bass? The subwoofer level controls the actual sub bass.
correct. i stated that already.
bass level changes 60/80/100/200hz
sub level changes everything below the LPF setting (should be set at 85)
Well if thats the case then everything is fine.... if i want more i should adjust the bass eq? but i thought pumping that up is bad
so if you turn the HPF off... does the bass level go to 0?
if u want more bass u either need to turn the headunit up more, turn the gain up more... or different subs/box/bigger amp.
an eq should not be used to boost what is lacking... its best used to quiet whats too loud
If i turn the hpf off i am free to adjust the bass from -6 to +6 and the hz but with it on it is stuck at -6 and 60
Bingo! makes sense now. what hz is ur HPF set at?
that setting will not affect the subwoofer preout.
it seems the headunit uses the eq to lower signal... which is the same thing as a high pass filter.
OK, so it can change without HPF off? Have you set your rear RCAs to SUBW yet?
EDIT: Just read Decaf's post. Makes a little more sense now lol.
10501650_10203332501847103_1859383749711
Blown
The hpf only has a on and off setting. do i go into my mids and treble to mess with those hz? i believe my mids are at 100 and my tre at .5khz
They were set to subw the first time.
then turn it off
2010 Chevrolet Cruze
Radio --- pioneer mvh-200vbt
Sub Control --- Pac LC1
Sub Amp --- GZPA 1.4K
Sub --- GZNW 15XSPL D1
Battery - GZBP 12.2500X
  • Who's Online   0 Members, 0 Anonymous, 1562 Guests (See full list)
