HPF makes my woofer very quiet
nitwimp
oh you should have 2 sets...at least
once again...what radio are you using??
2010 Chevrolet Cruze
Radio --- pioneer mvh-200vbt
Front/back --- alpine type s 6.5"
Sub Control --- Pac LC1
Sub Amp --- GZPA 1.4K
Sub --- GZNW 15XSPL D1
Battery - GZBP 12.2500X
There in lies your problem. HPF will HPF all deck outputs(I believe). Therefore, when it is turned on, then it will affect your sub amp.
Unless the set of RCAs you use is for Sub only.
10501650_10203332501847103_1859383749711
Blown
Do you have three sets of RCAs? Also, if you do, are you using the Sub set of RCAs? If so, then what phase are you set at, and what level is your sub output on your deck at?
If you only have two sets of RCAs, then you cannot use HPF
x 10 !!!! this is your answer.... he said something about I/O on the sub/rear .....that to me means its sub/rear switchable which isnt a "true" sub preout. so yea you cant use hpf on that deck if you have a sub hooked up to the rear channel (even if it is set on sub) i would go out and buy a headunit with 3 preouts front, rear, and sub. best thing you could do.....
i think there real i was looking through that guys stuff he sells and it looks like he finds stuff at auctions and just sells it
Yea, it looks like someone got the mids about a month ago....shit. If I had a whole Hertz front stage my ears would jizz all over my cheeks.
/ LOL
My Low Budget Build:
Green 1995 Subaru Legacy wagon 147k- $1K
headunit- pioneer premier deh-p650-$25
4 Lead acid batts. 1 up front and 3 in back- vented outside.- $50
4 vvme L11 10"s <- $30 shipped a piece
6 cu. ft box (after displacment) tuned to 32ish hz with 10 inch sonotube. -about $50 all together maybe a lil more
2 aspm 1300 strapped
Selenium 6"s in the front doors on headunit power- for now -$20
quantum tweets in door-for now -$10
boston acoustic 5 1/4 in rear doors- for now-Free
big 3
1/0 and 4awg throughout.
roof sound deadened (not peel n seal ftw)-free
on 80 amp alt (bench tested to put out 100 amps faithfully) <--?-$10 for test
about $430 for everything<----Not bad at all
still gotta add 3 way crossover, amp for front and rear door speakers and maybe eq
let say that he HAS 2 sets of preouts...one set for the front and one set for the rear speakers
so the thing is...why not sacrificing the rear speakers for the sub(you surely wont need rear speakers)?
in that case the HPF wont affect the sub
jvc krd 620
Yes only one set of rcas going to my sub
you mean Jvc KD R620?
jvc krd 620
totally.
THEN.....CHECK these
it doesnt have a sub pre out...
but you can sacrifice your rear speakers for the sub....and the HPF wont affect the subs
it worked for me
++++it has 2 SETS of preouts
but it will affect the sub because its still a TRUE rear channel so the headunit WILL apply hpf settings to it NO MATTER WHAT...... ive been here done that on alot of h/u and there is no way around it..... either turn your hpf off or dont run a sub..... lol my 2 cents
/ LOL
big 3
jvc krd 620
totally.
it worked for me
ill gladly sacrifice my rears for my sub. so just use the other set of preouts? finally something worth trying.
  • Who's Online   0 Members, 0 Anonymous, 1046 Guests (See full list)
