gally Posted September 24, 2011 Report Posted September 24, 2011 Nit..if resetting your deck settings doesn't work, unplug the power to it and try it that way. I love VW. Get the whatever VW but with the TDi. Getting the wife the new Jetta Wagon with a TDi in March or April. MK4 GTI? Nice! Not many other cars I really like other than Audi or VW lol 1.8? 2010 Chevrolet Cruze Radio --- pioneer mvh-200vbt Front/back --- alpine type s 6.5" Sub Control --- Pac LC1 Sub Amp --- GZPA 1.4K Sub --- GZNW 15XSPL D1 Battery - GZBP 12.2500X
Decaf Posted September 24, 2011 Report Posted September 24, 2011 Go to menu and look for pro eq then L/O mode and switch it to SUBW. pg 14, pro eq, switch L/O mode to SUBW http://resources.jvc.com/Resources/00/01/50/GET0735-001A.pdf Stop copying me! great minds think alike. (and there seems to be forum lag today) I've try'd that, no luck there either. the bass eq on the amp makes a difference but isnt it not goood to pump that think up? ive never once used any boost of any sort on an amp. i also do not add signal to anything below ~100hz on a headunit eq bass is stuck at -6 and 60hz and 2.0 whatever that means. can u change the frequency to 80/100/200? 2.0 is the width of the boost, aka the Q. the larger the number the larger number of frequencies are affected by the boost.
sayhuh? Posted September 24, 2011 Report Posted September 24, 2011 Go to menu and look for pro eq then L/O mode and switch it to SUBW. pg 14, pro eq, switch L/O mode to SUBW http://resources.jvc.com/Resources/00/01/50/GET0735-001A.pdf Stop copying me! great minds think alike. (and there seems to be forum lag today) I've try'd that, no luck there either. the bass eq on the amp makes a difference but isnt it not goood to pump that think up? ive never once used any boost of any sort on an amp. i also do not add signal to anything below ~100hz on a headunit eq bass is stuck at -6 and 60hz and 2.0 whatever that means. can u change the frequency to 80/100/200? 2.0 is the width of the boost, aka the Q. the larger the number the larger number of frequencies are affected by the boost. I say just disconnect the deck from power for a few minutes and let that reset it. Kinda like a hard reboot. Blown
nitwimp Posted September 24, 2011 Author Report Posted September 24, 2011 Go to menu and look for pro eq then L/O mode and switch it to SUBW. pg 14, pro eq, switch L/O mode to SUBW http://resources.jvc.com/Resources/00/01/50/GET0735-001A.pdf Stop copying me! great minds think alike. (and there seems to be forum lag today) I've try'd that, no luck there either. the bass eq on the amp makes a difference but isnt it not goood to pump that think up? ive never once used any boost of any sort on an amp. i also do not add signal to anything below ~100hz on a headunit eq bass is stuck at -6 and 60hz and 2.0 whatever that means. can u change the frequency to 80/100/200? 2.0 is the width of the boost, aka the Q. the larger the number the larger number of frequencies are affected by the boost. Nop it is stuck at 60 aswell.
Decaf Posted September 24, 2011 Report Posted September 24, 2011 Go to menu and look for pro eq then L/O mode and switch it to SUBW. pg 14, pro eq, switch L/O mode to SUBW http://resources.jvc.com/Resources/00/01/50/GET0735-001A.pdf Stop copying me! great minds think alike. (and there seems to be forum lag today) I've try'd that, no luck there either. the bass eq on the amp makes a difference but isnt it not goood to pump that think up? ive never once used any boost of any sort on an amp. i also do not add signal to anything below ~100hz on a headunit eq bass is stuck at -6 and 60hz and 2.0 whatever that means. can u change the frequency to 80/100/200? 2.0 is the width of the boost, aka the Q. the larger the number the larger number of frequencies are affected by the boost. Nop it is stuck at 60 aswell. put the eq to flat then... voila. problem solved
gally Posted September 24, 2011 Report Posted September 24, 2011 really? if that what decaf says gonna work...i might just buy a new battery 2010 Chevrolet Cruze Radio --- pioneer mvh-200vbt Front/back --- alpine type s 6.5" Sub Control --- Pac LC1 Sub Amp --- GZPA 1.4K Sub --- GZNW 15XSPL D1 Battery - GZBP 12.2500X
nitwimp Posted September 24, 2011 Author Report Posted September 24, 2011 is decaf actually being serious about flat?
Decaf Posted September 24, 2011 Report Posted September 24, 2011 is decaf actually being serious about flat? yes I am... it turns all levels to 0 aka flat. then go to eq and see if bass level is at 0
gally Posted September 24, 2011 Report Posted September 24, 2011 try it 2010 Chevrolet Cruze Radio --- pioneer mvh-200vbt Front/back --- alpine type s 6.5" Sub Control --- Pac LC1 Sub Amp --- GZPA 1.4K Sub --- GZNW 15XSPL D1 Battery - GZBP 12.2500X
sayhuh? Posted September 24, 2011 Report Posted September 24, 2011 is decaf actually being serious about flat? Yep. Also, consider my idea if it doesn't work. Unplug the plug from the back of the deck and let it sit a few seconds. When you plug it back in, it will be back at manufacturing settings Blown
