splcb7 Posted September 26, 2011 Report Posted September 26, 2011 Hay guys im thinking about checking out some diff amps.....i need to find an amp that runs under 1000rms at 4 ohms and has great power at 1 ohm or even .5 id prefer. .5 what do you guys recomend? Quote
bassrace Posted September 26, 2011 Report Posted September 26, 2011 What are you trying to do? How much under 1000rms @4 ohms are wanting ... Give us some real numbers Quote 145.9@40hz 145.3@34hz big 3 X2 group 34 Deka Group 31 All 0/1 awg jl meta wire Alpine CDA 7894 Orion HCCA D5000 2 AQ HDC312's Crunch gpv1100.2 (for 6.5"s only) AQ pro audio 6.5" - 3 sets AQ supertweeters - 2 sets 2000 Slamry
Torres Posted September 26, 2011 Report Posted September 26, 2011 i recommend not running an amp at .5 Quote
splcb7 Posted September 26, 2011 Author Report Posted September 26, 2011 What are you trying to do? How much under 1000rms @4 ohms are wanting ... Give us some real numbers Quote
splcb7 Posted September 26, 2011 Author Report Posted September 26, 2011 Anything under 1000rms that hits big numbers at 1 -.5 ohms ie i have an ma thats rated at 800rms at 4ohms and is rated at 3600rms at 1 ohm i need more power but dont want to go up in classes...so im seeing whats out there.... Quote
bassahaulic Posted September 26, 2011 Report Posted September 26, 2011 (edited) http://www.sundownaudio.com/index.php/products/item/saz-4500d.html?category_id=1 What class are you trying to stay in? USACi MOD 0-1000? Edited September 26, 2011 by bassahaulic Quote
STEvil Posted September 26, 2011 Report Posted September 26, 2011 fusion fca4000d... uhh.. kinda hard to find though lol Quote MickyMcD - "Capable of making some serious trouser flapping volumes at where's-my-testicles frequencies, the Servo-Drives used to be fairly jaw dropping..." Any time you have have a power wire next to your frame put some rubber hosing (or cut up an innertube) around it. The wire is bound to wiggle (due to driving or flex) and the casing will eventually wear through. Hammerdown... 1% no links to outside websites, business related FB/YT pages allowed.
bassahaulic Posted September 27, 2011 Report Posted September 27, 2011 Oh.... hmmmm Since you can only get down to .5ohm you might be best off finding two amps that do 500rms each at 4ohm and running them strapped at .25 each for SPL only. Or, if your series about this and you only want one amp you should get different woofers with the ability to go to a lower ohm load. .33 or lower so you can really get some power flowing. If you can get low like that I'd reccomend an RD Audio D9, Sundown Audio SAZ-4500, Atomic 5000, or something along those lines. Quote
splcb7 Posted September 27, 2011 Author Report Posted September 27, 2011 Oh.... hmmmm Since you can only get down to .5ohm you might be best off finding two amps that do 500rms each at 4ohm and running them strapped at .25 each for SPL only. Or, if your series about this and you only want one amp you should get different woofers with the ability to go to a lower ohm load. .33 or lower so you can really get some power flowing. If you can get low like that I'd reccomend an RD Audio D9, Sundown Audio SAZ-4500, Atomic 5000, or something along those lines. Ok cool thanks ill go check out those amps....i might change subs two if i see an chance for gain....2 500rms amps at 4 ohm loads work two it dosnt have to be just one amp im after most rms i can get in the 1000rms at 4 ohm range.....so 2 500rms amps are ok two.... Quote
