what amps run under 1000rms at 4 ohm and make good power at 1ohm?
Hay guys im thinking about checking out some diff amps.....i need to find an amp that runs under 1000rms at 4 ohms and has great power at 1 ohm or even .5 id prefer. .5 what do you guys recomend?
What are you trying to do? How much under 1000rms @4 ohms are wanting ... Give us some real numbers
145.9@40hz
145.3@34hz
big 3
X2 group 34
Deka Group 31
All 0/1 awg jl meta wire
Alpine CDA 7894
Orion HCCA D5000
2 AQ HDC312's
Crunch gpv1100.2 (for 6.5"s only)
AQ pro audio 6.5" - 3 sets
AQ supertweeters - 2 sets
2000 Slamry
Anything under 1000rms that hits big numbers at 1 -.5 ohms ie i have an ma thats rated at 800rms at 4ohms and is rated at 3600rms at 1 ohm i need more power but dont want to go up in classes...so im seeing whats out there....
fusion fca4000d... uhh.. kinda hard to find though lol
Hammerdown... 1%
Oh.... hmmmm
Since you can only get down to .5ohm you might be best off finding two amps that do 500rms each at 4ohm and running them strapped at .25 each for SPL only.
Or, if your series about this and you only want one amp you should get different woofers with the ability to go to a lower ohm load. .33 or lower so you can really get some power flowing.
If you can get low like that I'd reccomend an RD Audio D9, Sundown Audio SAZ-4500, Atomic 5000, or something along those lines.
Oh.... hmmmm
Ok cool thanks ill go check out those amps....i might change subs two if i see an chance for gain....2 500rms amps at 4 ohm loads work two it dosnt have to be just one amp im after most rms i can get in the 1000rms at 4 ohm range.....so 2 500rms amps are ok two....
  • Who's Online   1 Member, 0 Anonymous, 1269 Guests (See full list)
