I bought the 3500D to eventually use with an 18" BTL but I'm not putting the BTL in until next summer now. For now I'm going to throw a couple L7 12 Dual 4's in. I plan on running them at a final 4 ohm load which the 3500 puts out about 1100W RMS at. My question is will I need to use 1/0 Gauge to hook up the L7s to the amp or can I use 4 Gauge and be fine? I already have 4 gauge ran through my car because I had a couple Type Arrghs before this and I'd rather not have to run 0 gauge through my entire car right now if I don't need to.
:drink40: Thanks
You can get by with 4 gauge at that level just fine. 4 gauge is good up to around 1600rms
2002 Camry XLE
35% tints all around
17'' Enkei FD-05 rims
Fi Q15 in 3.8cu ft box tuned to 32Hz
Pioneer DEH-P7200HD
AudioQue AQ1200d
4 Gauge Tsunami wiring/RCA's
mids/highs - OEM JBL system
AudioTechnix Deadner
Big 3 upgrade
My YouTube
0 gauge is not necessary for 1100w.
Headunit - Sony DSX-200X
Subs - (2) Modified American Bass 18's
Monoamp - DD M4
Front Stage - CDT HD62-AS components with
4 Crescendo PWX 6.5
4 Channel Amp - Hifonics ZRX1000.4
Cadence 0 gauge
Singer 275 amp Alt
D7500 XS Power battery
Quad 1/0 input Toolmaker terminals
SMD OM-1
RGB LEDs
BUILD LOG CURRENT ABOVE SETUP http://www.stevemeadedesigns.com/board/topic/191602-2003-bravada-2-18s-ab-dd-xs-singer/
BUILD LOG (2 MTX 7512's)http://www.stevemead...__fromsearch__1[/size]
4 gauge isn't adequate for 1100 rms. Box rise will more than likely save you though. If you don't have true copper 4 gauge, I'd tread lightly. if you don't have stable voltage, I'd be even more careful.
yes it is. My RF T1500 only has 4g inputs, hopefully RF knows at least a little about what they are doing.
F150:
Stock :(
2019 Harley Road Glide:
Processor: DSR1
Lid (Rear) 6x9s -  TMS69
Ok everyone except zayres please stop talking! Do the math on the current required to get 1100 watts @ 4ohms and not just think about what it takes at 1ohm. Please use your head. Use 0 gauge wire it requires 0 gauge for a reason it needs the ability to pull current. now unless you 4 gauge is only 4 feet long get 0 gauge
Edited by OldsBoomer
Johns.jpgSuburban Coming Soon
My math is as follows... 100 watts @ 12 volts = 10 amps. That being said, 1100 watts @ 12 volts = 110 amps. I've been under this impression for a couple years now, so correct me if I'm wrong. I never calculate at 14.4 because perfect voltage is a rarity. Like I said, correct me if I'm wrong.
