Isolator is not what you need in this application. Save that money and add a battery to the back. DO NOT FORGET to fuse the power cable coming off of the front battery and just before the back battery. A 3100 in the back isn't going to strain your alt too much, but you probably would be fine with a 3400.
So you should put a fuse coming off of the front batt, then another fuse right before the batt bank and then another fuse between the batt bank to the amp?
So 3 fuses total?
Most people put a 300A fuse at either the front, back, or both sides but most people pick one or the other. I'll be fusing it closer to the rear battery.
That's what I initially planned to do. I was putting a 300a fuse on the front batt then running that to the back. Then putting a 300a fuse from the back batt to the amp. So I will just stick with that.
Diagram?
Sorry no diagram I will do that once its actually install. My system plans have changed so much over the past couple of months, haha.
Started putting together a 4k system, then upgraded to 7k system now I am back down to a 4.5k/5k setup. My main concerns were potential electrical issues (plus equipment delays).
Did u really say thar lil diff beteew yellow top and d3100 smh so worry
2003 Grand AM GTELECTRICAL SYSTEMAlternatorstockBatteryFront s3400back d3100Wireinglots of 0gaHEAD UNITpionner 7500xSPEAKERS(4)Prv 6mb200(2)prv 10mr1000AMPLIFIRLS(1)Zxi80.4(2)Brx1200.4SUBWOOFER(2) MTX 9500BOX3.41 cuft 63sq port 34hzLINKSYoutube.com/reggieb198895
