OK guys i need some help.
i have a pair of dc 9ks and im not sure what to do as far as batts
12v vs 16v batts?>...
i already have 2 alts on my truck . i can either go 12v batts and use both of my alts to charge or go with 16v batts and only use one alt to charge my 16v batts/ sub stage and the other one for my trucks 'stock electrical'
what would be\\work better for me ?....
i do not drive my truck daily
also i have 4 18'' rd super heavy weigths that are dual 1's
my plan was to wire a pair of subs to each amp for daily @ 1ohm
and strapp them @ .25 each for a total load of .5ohm for burps...
PROS AND CONS OF THE 12V AND 16V ??....
EDIT; BATTS WOULD BE xs power d3100's or d1600's/xp1000's
i need some HHEEELLPP
Do you mean strap at .5 for .25 ea?
If this is just a comp setup and you dont have to worry about wiring for a 12/18v set up I'd go with the most voltage I could get. lol
yeah .25ohm each amp...
i would like to be able to do 1min demo's and play music ' safe ' ... :)
money wise i think ill spend the same amount 12v or 16v since i already have everything BUT batts...
