I did it again and got you all hahaha.
So basically im starting to think about running a 16v set up next year. Yeah i know i need a alt and step down thats not my problem.
So how do you know how many batteries you need. Because they dont have as many AH as a normal 12v battery does. I plan on running 4 d9s possibly i know 2 for sure.
Also i have heard that running 16v daily aint the best for amps. Is that true or not. This will be a daily driver
What all would it take to run 2 d9s daily first. Before you get carried away with the 4 d9s
Edited by Noobtastic14
- 1998 Ford Mustang -
Time to rebuild.
4 15s and alot of power
TEAM DTF
16 volts is easier on the equipment .I run 16 volts daily with no issues ...i charge @ 19.5++..
From what i understand you have to have double the batteries you would with a 12v system.
I got one person saying he does a 2:3 ratio 2 16v to 3 12v
And another saying he does 2 16v to 1 12v......If this is right thats alot of batteries
Time to rebuild.
TEAM DTF
its amazing how fast you can go from no views to 40 views just by putting the letter DC on the forums
Time to rebuild.
TEAM DTF
I knew you were lying. :-) imo it depends on the amps and how they are built. My dd amps get a lot hotter since I stepped up to 14v. And 3 to 2 ratio is good. I run 6 batts on 10k. Pretty sure the 14 and 16 have same ah
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
From dc to Sony? Your views are gonna go negative lol.
--2004 Toyota 4runner
New Build Log
-2002 Acura Tl-S
Old Build Log
Team DC Audio
spl dust is an option you can get on the coils... it's great for extra 1000 watts of power
where can i get this spl dust and how much is it. is it hard to apply? lol
Keep your title on topic.
This is just a cheap gimmick for getting thread views.
-Drew
uhoh_45 said:
See there is another new ratio. so how much power would i be good for if i got 10-12 16v batteries
Time to rebuild.
TEAM DTF
  • Who's Online   0 Members, 0 Anonymous, 780 Guests (See full list)
