Keep your title on topic.
This is just a cheap gimmick for getting thread views.
-Drew
your no fun. There aint to many people here that know about 16v systems and the ones that do dont like to explain them so i have to do something to draw there attention.
- 1998 Ford Mustang -
Time to rebuild.
4 15s and alot of power
TEAM DTF
I knew you were lying. :-) imo it depends on the amps and how they are built. My dd amps get a lot hotter since I stepped up to 14v. And 3 to 2 ratio is good. I run 6 batts on 10k. Pretty sure the 14 and 16 have same ah
See there is another new ratio. so how much power would i be good for if i got 10-12 16v batteries
I don't believe in a lot of batteries it works when you don't have enough alternator and with 16v your drop should never be under 16v with 2 d9s with 4 id put as many as possible. For example with all 3 of my alts 1050 amps hooked up I drop .2 fulltilt on clamped 10k playing music. With 1 350 alt hooked up and 6 14v batts I. Will drop a full volt or too battery resting voltage. My amps draw 900+amps
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
So your saying that DC fanboys are the only ones that know about 16v?
Try and target people that you know that run 16v and send them a PM or two. Get your information from a reliable source rather than bringing in anybody wanting to see pictures of sweet gear. Also, When i was new to the site I had my thread deleted because I used a gimmick title to get views so a simple title change is gracious.
-Drew
uhoh_45 said:
alright I am going to have to get a custom alt made for it anyway so i will try to get a 350ah. I cant fit dual alts which sucks so thats why i need alot of batteries
Time to rebuild.
TEAM DTF
Then as many as you can do is the ticket
TEAM DC AUDIO
PREAMP:arcaudio
SUB AMP: 2-dc7.5s
BATTERIES:6-d1400s
alright i am just making sure about 10 would atleast be enough to keep my 2 d9s going with no problem
Time to rebuild.
TEAM DTF
This is how I understand it... If I'm wrong please sort me out ;)
Find out how many cells what you are comparing has. So for example an XS 12v has 6 cells at 2-2.24v each. To get up to 16v (4v difference) that's 2 more cells in the same amount of space or 1/3 less storage. So for every 3 batteries at 12 you need another at 16. That's in a perfect world so really you should be thinking in terms of 40%-50%.
If at first you do not succeed, you are doing it wrong! -ARS
Check out my walled TBSS build over here
4 Fi Team 18s on 2 Cactus K9
DS18 doors on 2 MBQ 1Ks, Vifa pillars on a STL4.500
Pioneer X8500
6 XS Power D7500, 1 3400S
Second Skin
2 270a Mechman Alts
  • Who's Online   0 Members, 0 Anonymous, 780 Guests (See full list)
