Just installed an AQ2200D and a 15 inch DC XL. Running it at 1 ohm I have pictures on the install and the settings on the amp. Electrical is pretty bulletproof 200amp alt, 2 XS 1200 batt's, 0 gauge everywhere including big 3. Doesnt drop below 13.8 volts. The clip light goes on pretty often, on the remote but sometimes the remote wont turn on and sometimes the power led doesnt work. Usually when it "hits" hard or theres a long bass note it stays lit. I dont hear any distortion i feel like the gain is where it should be its at about 2v and my deck has a 2v output. Do u guys think it looks right?
BTW, use the top of the notch to indicate where the gain and subsonic and lpf are. The boost is at zero.
Edited by triplec19
Use a dd1 your probably clipping
--2004 Toyota 4runner
New Build Log
-2002 Acura Tl-S
Old Build Log
Team DC Audio
spl dust is an option you can get on the coils... it's great for extra 1000 watts of power
where can i get this spl dust and how much is it. is it hard to apply? lol
when u ran ur remote wire did u make sure it was free from moving parts or sharp objects? check and see u might have a short in ur remote wire . just a thought .
Are you sure you're not running it at almost full tilt? Aquatic has backwards gain pots
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
A gain setter. Look on the site.
New Build Log
-2002 Acura Tl-S
Old Build Log
Team DC Audio
What is a DD1? and the wire isnt even run yet just plugged it in.
This is a dd1. It is use to set your gain properly.
http://wccaraudio.com/smd-distortion-detector-dd-1.html
Build Under Construction
Head Unit = Kenwood DDX514
Amps = Kicker 750.1, Going to install Sundown 1500D v3 and Sundown 125.4
Battery = XS D3400
Wires = Kicker RCA's, 0 Gauge street wire and Stinger
Mids and Highs = Stock
Sub= Kicker L7 12"
Alternator = 220 Mechman
Sound Deadner= Fatmat and Stinger Road Kill
damnnn 140 bucks for a one time test prob, n 3 week shipping. I have access to a really nice fluke voltmeter. We have oscilloscopes at school should i try and borrow one of those from the lab or go to a shop first n see if they can test it somehow?
