This is my Camper build a Ford transit LWB High roof 2.5Di so here is its life story and how I ended up with a camper and my audio install.
It started life as a newspaper van less then a year later my uncle bought it at an auction at in 2001 for is company I said to him then if you where to sell I'll buy it fast forward to new years day 2010 I get a call want to buy the van will be selling it in March well I said yes. I picked it up in March and drove it around as a panel van for a bit be it the van was fade more almost pink and had a few dents but only had 100,000 miles on the clock full services history and cost me €600. Well in October last year I started the camper install finished it a week before Xmass and went away in it. Skip on a bit more I caught fiancé in bed with my mate so I was a bit pissed and I disappeared for a bit on my travels I met another girl this is going somewhere she is almost deaf but loves music unfortunately can't here the radio in the camper when we go away so she went of and got me this
Subwoofer
its specs
* Subwoofer Size 12"
* Voice Coil(s) Single
* Impedance (per voice coil) 4 ohms
* Peak Power Handling 300 watts approx.
* RMS Power Handling 125 watts
* Woofer Surround Foam
* Sensitivity 87.6 dB
* Frequency Response N/A
* Top Mount Depth 6"
* Cutout Diameter 11"
Amp spec
* Class D Monoblock Full Range Amplifier
* High-Damping Class D Circuit with discrete contorl circuitry
* Pass-through RCA outputs
* On-board crossover: Variable Low-Pass Filter: 20 -200Hz, * Selectable Slope
* High level inputs
* CEA-2006 Compliant
* RMS Power Rating (14.4V):
* 4 ohms: 320 watts x 1 chan.
* 2 ohms: 500 watts x 1 chan.
* RMS Power Rating (12.5V):
* 4 ohms: 200 watts x 1 chan.
* 2 ohms: 400 watts x 1 chan.
* Frequency Response: 10 - 250Hz
* Damping Factor: >500 @ 4 Ohms / 50Hz, <250 at 2 Ohms/50Hz
* Input Range: 200mV - 8V RMS
* Bass EQ: +6dB Fixed Frequency, Fixed 'Q' with port for optional remote bass control
* Dimensions: 11.81" L x 9.25" W x 2.36" H
Speakers specs
Vibe SE-K69 Series
* 6" x 9" SEK-Series Tri-Axial 3-Way Car Speakers
* Power Handling:
Peak: 525 watts per set / 262.5 watts each side
RMS: 175 watts per set / 75 watts each side
* Black kevlar composite cone provides ultimate durability
* Polyurethane surround allows faster tighter bass delivery
and superior cone control
* 3/4" & 1" Pure silk dome tweeters provide a very clean and natural sound
* Alloy angular torsion chassis with vented airflow arms
* Oversized terminal posts with screw down clamps
* 4 ohms impedance
* 1-7/16" High temperature voice coil
* 20 oz. Neodymium magnet & motor structure for increased power handling
* Top-Mount Depth: 3-5/8"
* Cutout Diameter: 8-3/4" x 5-7/8"
* Frequency Response: 50-20,000 Hz
* Sensitivity: 90 dB
This are now in the camper
Mad Camper is what they call me why you ask well 32 lights on my camper
Moving from a camper to a small hatch back blow engine in hatch back buys a estate that spent 3 years in a field with only sheep as friends in all that time get married and become a full time care giver and loss out boot space for subs :(
Ok this is the install as its a camper I needed to have the everything up front
I made my own boxes
I had to cut the wall between the cab and camper
All that so I can fit in two of this
the amp is mounted on the wall on the cab side
My head unit
The Camper
Here are pictures of it at night
If you want to see more i will post the inside as well all built by me in the middle of winter
thats kinda cool definitely different.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
My niece got my GF to cable tied her teddy bear to my A bar looks funny cause his cable tied by his neck
I see an enormous building coming sometime with this.. :peepwall:
Definitely a cool camper, more pics of it?? :popcorn:
2004 Bagged Trailblazer
(4)18" Sundown Nsv3s
(4) Taramps HD10000s, Taramps DSP3000, Lanzar opti 250x2, AB 100x4
(2)DC power SP 270s, (14)XS Power d3100s, (1)d6500
id so do couple18s in a 6th order..
AUSTRALIA do i need say more?
HU: some crap pionee
AMP: dc 9k @ 18v
SUB: 4 elevation audio sqx 12"
Battery: 2 neuton power 8200d
burp setup for fun 152's
soon to come: rebuilt soundstream xxx (2 18" OR 3 15" wall) Bunch speakers, more batts and new HU
I think the big build is done but in saying that my GF now wasn't there when I did it first time and I didn't do a good job middle of winter in the snow so I may rip it all out and start again but I will get a better cooker and sink and other bit before then better pictures will come Tuesday as I'm not near my desktop pc I'm on the tablet again works better then the pc
Here is all the build pictures not many of the inside since done but picture this pink walls blue trim blue and pink doors orange seat 70s curtains
This is what as been done to it to date
  1. Add side marker lights high and low ones
  2. Add front roof maker lights
  3. Extra back lights above the back door
  4. A flashing beacon
  5. Yellow spot on the A bar
  6. 4 high beam lights on the roof lights
  7. Extra reversing light which are working lights too
  8. Reversing camera hooked up to a LCD colour screen
  9. Audio install
  10. Wind deflectors
  11. Made car seat covers fit my seat
  12. Did the camper van conversion
  13. Electric windows
  14. There is more but I can't remember them
Have to point out I drive this every day
Post man came with some new battery terminals there 100% solid brass when i get home i will put them in should help things a bit
