KenC210 Posted October 2, 2011 Report Posted October 2, 2011 If i wire like this would i see problems? And if the channel its on is getting about 160wrms how would that power be distributed through the speaker wire? is it 80wrms through the to 4 ohm loads then 40wrms to the tweeters or will each speaker see 54 wrms? edit: the mid-bass is 8" Kids Cadi Power Wheel Build2007 Ford Escape Build2012 Toyota Corolla Build 2013 Toyota Tundra
captainhook426 Posted October 2, 2011 Report Posted October 2, 2011 You need a cross over in there some where, I'm pretty sure. your ohm load is correct, but your going to be putting all your frequencies through all of the speakers. to answer your real question, the power (in theory) is going to be equal between the tweets and the mid-bass. Next time she tries to punch you in the stomach, whip your wiener out and chase her around. Show her who's boss.
KenC210 Posted October 2, 2011 Author Report Posted October 2, 2011 yes i will have a crossover. i am just wondering cuz i aint to sure on the power i will be getting. So... hook426 you are saying i will get the 54wrms i guess? Kids Cadi Power Wheel Build2007 Ford Escape Build2012 Toyota Corolla Build 2013 Toyota Tundra
KenC210 Posted October 3, 2011 Author Report Posted October 3, 2011 Can someone help me with this? Just want to be clear on this power rating to each speaker. I may be wrong but theoretically with a wire at a resistance of 2ohm would get the 160wrms then once the wire gets divided to the 4ohm load would then see 80wrms to each wire and then once divided the third time at the tweeters when it divides again at the 8ohm load it would see a 40wrms. Am i wrong in seeing it this way? Can someone with more knowledge clear this up for me? Kids Cadi Power Wheel Build2007 Ford Escape Build2012 Toyota Corolla Build 2013 Toyota Tundra
chronic2001 Posted October 3, 2011 Report Posted October 3, 2011 The power should get evenly distributed to the speakers. Just because your speakers are different ohm loads doesn't mean they will receive different wattage, that will only affect the final load coming from your amp. Different ohms on speakers are just so you have more wiring options to suit your specific needs. If you have a mono amp that is 1 ohm stable and you only have 1 dual voice coil sub you can buy a dual 2 ohm sub and wire to 1 ohm load. Hope that clears things up. At least that's my understanding. I'm sure someone will correct me if I'm wrong. Pioneer deh-8300UB 6- Image Dynamics CSX6.5v2 4-Image Dynamics XS-28 tweeters 4-Sundown Audio sa8v2's 1-Sundown Audio SAX-200.4 1-Sundown Audio SAX-1200d 1-Mechman 270a alternator 1-XS Power D3400 under hood Second Skin Damplifier Pro Deadener Kicker & Knukoncept 1/0 wiring Big 3 upgrade
KenC210 Posted October 3, 2011 Author Report Posted October 3, 2011 o well i guess i will be needing another amp later... boo, i was hoping the way i thought was wrong. so as i figured i will be getting 53wrms to each of those speakers. Was hoping i was wrong. does anybody know how to see how much power each speaker is getting? Kids Cadi Power Wheel Build2007 Ford Escape Build2012 Toyota Corolla Build 2013 Toyota Tundra
