my plan is official now.
i sold my 2 memphis 12s in the box with a 600 watt amp for $250
and bought 2 hx2 fosgates for $225
so now i officially own 4 of the same subs lol :clapping:
they are being shipped so ill let you know when they arive :yahoo:
im gonna be running them still with my 3500watt boss amp till i can get the 2 JLs
now comes the work of building the box <_<
I sent you a couple PM's just let me know if you need anything. (reply in PM though please)
"The strongest reason for people to retain the right to keep and bear arms is, as a last resort, to protect themselves against tyranny in government." -- (Thomas Jefferson)
i have another couple questions
i should use mdf board right?
and whats the advantage/disadvantige of downfiring subs? casue i think it would look cool but if its not good or whatever just let me know
Do you mean Downfiring or inverted? Also, some guys use MDF,some use birch. If weight is a concern, go with birch. It's more expensive per sheet, but a hell of a lot lighter.
for your situation i dont believe downfiring would be beneficial at all
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
flipped upside down so you see the magnet. i dont know the difference between those two
and weight doesnt matter so i guess ill go with mdf
That's called inverted man, not downfired. Saw dust from MDF is a nightmare too, just FYI.
aight..my bad then lol.
cause im thinking of inverted in a sealed box. for looks and the simplicity of my first build
or should i really do a ported?
if i do ported though, where would be the best place for the port(s)
facing up, back, or forward?
and would it better to have not enough of a port, or too much? im gonna try to get as close as possible but just wannna know if i should go smaller or bigger
IIRC you have an SUV. the most common setup i've seen is subs up, ports back. and it's better to have just enough port.
i'd gladly design you a box for the fosgates. i can't stress to you enough the importance of doing it right the first time. PM me if you have any questions, or check out my facebook page to see more designs
Just say no to Ground Pounder Customs.
More box builds
some cars do over 170db with one sub, so clearly my two 12"s can do that in my car, with my knowledge too! look out bitches!
I'm with captain stupid.
