Advice on sq build.
Reveth
My 1st post on this thing! whats good?! anyways back on topic... trying to build a sq system. i need help trying to figure out which components i should run with my amp and if i should even bother putting rear speakers back in. any suggestions welcome. budget $600
Vehicle-2002 Montero sport
Amps- Zapco ref 650.6 & JL 1000v1
Sub- jl2w7-3 in ported box @ 32hz
speakers- infinity 6032cs front, 6032si rear
Head unit- Kenwood excelon x794
do you want a two way front stage or 3 way? stock locations or custom? do you have a processor?
A couple ideas to look into:
Focus on front stage, look into 2-way or 3-way components
-Rainbow
-Top-end Image Dynamics
-Morel
Also you want to build an enclosure with 22-30 hz tuning with SQ, trying to optimize as flat of a response as possible. You dont want the crazy frequency peaks like most ported enclosures, SQ is all about efficiency.
A sub will act as your rear fill, especially with a powerful front stage.
Judging by your amplifier, you might want to lean towards a 3-way front stage and pick up a 6ch processor and eliminate any crossovers, they will be uneeded. With say an Audiocontrol 6ch eq/x-over, you will have all tuning capabilities, so piecing together a front stage is very optimal.
So in short:
-powerful 2-way or 3-way
-low tuned box ideal 22-25 hz
-6ch processor (eq & x-over combo)
-Zapco amp is amazing
-JL amp is efficient with sub stage
Good luck, sounds like it has great potential
Pioneer AVH480
Zapco ST5XII amplifier
Stevens Audio 6.5" components (passive)
Onyx Subwoofer
Sky High OFC wiring
im looking for a front stage with the same budget and i just came across the DLS gothia 6.3. it looks like a killer 3way comp set.i have not heard the, but im seeing great reviews and will probably be the set i end up with.
mid / midbass drivers going in the doors or the kicks ??
a processors does a lot actually. it will give you a lot more EQ options as well as time alignment. it will let you change your crossover settings and the slope so you can blend the speakers. it also means going active so you need more amplifier channels, one channel per speaker. but going active actually helps you get your front stage louder if that is a concern.
  • Who's Online   0 Members, 0 Anonymous, 1401 Guests (See full list)
