No get the dual 2. And wire it parallel, it will give you a 1 ohm load.
Ok so for sure get the 2 ohm sub
Unless that amp can do. .5 daily and your electrical can handle it.
Safe bet get the d2
Edited by vettedude102
2 polk audio 4x6'skenwood head-unit 220 amp Mechman alt1979 Corvette
2003 corvette z06
alpine radio and the bose system that came stock
When ordering the N2 select the Dual 2 option. This will allow you to wire it to 1-ohm nominal. Don't try to run your amplifier at. 5-ohms. Yes the amplifier is capable with proper electrical, but from your questions, you will be more than happy leaving it at 1-ohm.
When the sub comes in there will be two + and two -. Wire the + to the other + and then to the amplifier's +. Next wire the - to the other - and then to the - on the amplifer. You will then be good to go with a 1-ohm nominal load on your amplier. :good:
On 6/30/2011 at 1:11 AM, 'Ray' said:
Acoustical energy is free. Electrical energy is not.
Get a dual 2. You can wire it to 4 or 1 ohm. Look up ohms law for more info on ohm load stuff and resistance.
Thanks bro
  • Who's Online   1 Member, 0 Anonymous, 1053 Guests (See full list)
