Jd1102 Posted October 6, 2011 Report Posted October 6, 2011 How come? :s if you get dual 1's then final ohm load would be .5ohms(Parallel wiring) or 2 ohms(series wiring) Quote
pitbullninja Posted October 6, 2011 Author Report Posted October 6, 2011 Ugh so 2 ohm sub would be 1 and 4? Quote
pitbullninja Posted October 6, 2011 Author Report Posted October 6, 2011 No get the dual 2. And wire it parallel, it will give you a 1 ohm load. Ok so for sure get the 2 ohm sub Quote
vettedude102 Posted October 6, 2011 Report Posted October 6, 2011 (edited) No get the dual 2. And wire it parallel, it will give you a 1 ohm load. Ok so for sure get the 2 ohm sub Unless that amp can do. .5 daily and your electrical can handle it. Safe bet get the d2 Edited October 6, 2011 by vettedude102 Quote 2 polk audio 4x6'skenwood head-unit 220 amp Mechman alt1979 Corvette 2003 corvette z06 alpine radio and the bose system that came stock
pitbullninja Posted October 6, 2011 Author Report Posted October 6, 2011 Well the amp can but idk about electrical Quote
Cashdollar2009 Posted October 6, 2011 Report Posted October 6, 2011 When ordering the N2 select the Dual 2 option. This will allow you to wire it to 1-ohm nominal. Don't try to run your amplifier at. 5-ohms. Yes the amplifier is capable with proper electrical, but from your questions, you will be more than happy leaving it at 1-ohm. When the sub comes in there will be two + and two -. Wire the + to the other + and then to the amplifier's +. Next wire the - to the other - and then to the - on the amplifer. You will then be good to go with a 1-ohm nominal load on your amplier. Quote On 6/30/2011 at 1:11 AM, 'Ray' said: Acoustical energy is free. Electrical energy is not.
corey0928 Posted October 6, 2011 Report Posted October 6, 2011 What does your electrical look like Quote
ChevyBoy95 Posted October 6, 2011 Report Posted October 6, 2011 Get a dual 2. You can wire it to 4 or 1 ohm. Look up ohms law for more info on ohm load stuff and resistance. Quote Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/
pitbullninja Posted October 6, 2011 Author Report Posted October 6, 2011 When ordering the N2 select the Dual 2 option. This will allow you to wire it to 1-ohm nominal. Don't try to run your amplifier at. 5-ohms. Yes the amplifier is capable with proper electrical, but from your questions, you will be more than happy leaving it at 1-ohm. When the sub comes in there will be two + and two -. Wire the + to the other + and then to the amplifier's +. Next wire the - to the other - and then to the - on the amplifer. You will then be good to go with a 1-ohm nominal load on your amplier. Thanks bro Quote
