i was reading forever bumpins tutorial on tlines.
he says to find the SD/cone area of the sub to measure the outside of the surround across. say 11.5 inches. then divide by two to get radius and do R^2(3.14).
i was looking at DC's website and they say the SD of the level 3 12 is 494cm^2. when the formula that he gave only comes out to 103.82 in^2 which is only 263.7 cm^2.
so what measurement should i use? the one from the DC website? or what i just calculated.
i wanted to use my Alpine type r in a tLine just for practice. but i wanted to make one for the DC since they're numbers were posted on the website. im just trying to understand the concept before i waste time a money on a box like this.
The IrishmanDCSig.jpgCheck out my build hereXL 4th order wall build logIn Progress:alpine cda HU4th order Bandpass2xl 15's1- ab 400.1 (gonna be two hopefully)4- Crescendo 8's2- xts crecendo supertweeters
2 sq super tweetsMb quart 4.125Mechman 270a alt1- xs D27003- xs XP3000
4- odessey pc1700seller feed back threadhttp://www.stevemeadedesigns.com/board/topic/136418-d-train-13k/
bump
bump
also are you supposed to tune the box to the Fs of your sub for best results or is that for a one not wonder tline
I believe one of the woofers on the DC website has an area for SD, but I cannot remember which one. Give me a second and I'll check.
It's the Lv3 10 that is incorrect. I'd go with the given manufacturers SD.
Using the formula he gave, you are correct in saying it comes out to only 103 inches. But that formula is for finding the area of a flat, 2 dimensional circle. A subwoofer isn't flat, it dips in... So that seems like it would be the reason that the SD is 494. Idk I sucked in geometry lol
Edited by Supercharged DCs
tune to the fs of the sub or higher. depends on your preferences
and as far as i know there is no such thing as a one note wonder tline
all of them are very musical
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
Alright thank you. The FS on the alpine is close to 28hz buying tuning the box to 30hz with 180sqin of port. The sd of the alpine type r 12 is 480sqin.
Port dimensions are interior measurements at 8hx23wx4.3ft long.
Does that seem about right?
This is my first attempt at a tline.
Any help?
are you doing an 8th wave?
because if you are trying a quarter wave your length tunes to 65hz
and the sd of a 12 is no where near the 184 sq inches of port you have
Edited by IH8PunkRok
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
