Bagged 94 silverado Build Log (delilah)
I haven't posted on here in awhile but I've started a new project, I will start a new build for the audio. Now I've always wanted to have a project truck that wasn't a daily driver so if I mess something up it's no big deal if it sits. I was looking for a obs chevy or gmc, after about 2 months of not finding what I was looking for then one day I was driving home and found exactly what I was looking for about 15 minutes from my house. I pulled over got the phone number went back an hour later after a little bit of negotiations I left with a black 94 Silverado ext 2wd pickup. I immediately started ordering parts and spending countless hours working on the truck. I've owned it for about 90 days now and progress will become slower from here on out because I don't have a garage and Indiana winters are cold. Anyways here is somewhat of a picture timeline, also keep in mind this is my first time ever welding and doing body work on a vehicle.
Day I brought it home
Here is one with my Avalanche in the background
Interior
First was handle relocate
Then Rollpan
Then replaced damaged fender and hood
Then bed-sides
I bought a new plastic GMC grill and cut the center out
Scuffed it up with red scotch pads sprayed with bulldog paint adhesive
I went to a pull apart and got two used good doors for 100 bucks and purchased the AVS door popper kit.
Grinding area
Rebuild coming soon
You've got some pretty good welding in my book. :good:
UNDER-CONSTRUCTION
''Old School Build''
maybe it sounds like an 18 cause theres 3 fucking "port" holes ghetto drilled in the "box"
190 db when your done?
Yea that's the lowest decibal ill be satisfied with when I'm done like I said its stage one and I lost my job u guys should consider shit instead of just talk it
lmao
Also got new mirrors
Went back to pull a part and found these lower control arms for 35 bucks
Bought a cheap little sandblaster and started cleaning them up
Epoxy primed
Rattle can undercoating with some high temp black enamel
Rebuild coming soon
Well I lowered the back 4inches... My uncle owns a garage and was nice enough to let me use the lift and his torch, cut off tools, press, and air chisel.
Begining
UP UP UP... My cousin getting all the tools ready
We ran into all sorts of issues, first we broke one of the u-bolts on the rear end right off the back. We had several obstacles, but six hours later we finished.
I do plan on bagging it in April or May just wanted to see what was involved in lower it and I got a good deal on the lower control arms.
Rebuild coming soon
kool updates
CURRENT SYSTEM
(VEHICLE) 2005 JEEP GRAND CHEROKEE
(HEAD UNIT) KENWOOD KDC BT848U
(DASHBOARD) INFINITY KAPPA 32.9CF
(FRONT DOOR) JBL P693
(REAR DOOR) KENWOOD EXCELON KFC-X1730
(TWEETER) KICKER KS25 X 2
(SUB WOOFER) COMING SOON
(4 CHANNEL AMP) ROCKFORD FOSGATE T1000-4ADCP
(1 CHANNEL AMP) ROCKFORD FOSGATE T2500BDCP X 2
(PROCESSORS) AUDIOCONTROL DQXS & EPICENTER & MATRIX PLUS & DDC
(BATTERY) 1 OPTIMA YELLOW TOP
(SIGNAL WIRES) KICKER XI
(POWER CABLES) KICKER PKD1
(SPEAKER WIRE) KICKER 12 GAUGE
(INTERIOR) DYNAMAT
COMING SOON
2 FI SP4 18 COMING SOON
2 XS POWER XP3000 COMING SOON
DC POWER 270XP ALT COMING SOON
Got a couple more thing accomplished this week on her...
Control arms ready to go
Stock Front Height
New arms installed
Got other fender sanded and primed
Dads work truck for comparison
Rebuild coming soon
