Bagged 94 silverado Build Log (delilah)
This truck really went from shit to sexy in no time. Plans to put this truck on the ground?
That is the goal for it to lay out... I hope to bag it in April or May
Rebuild coming soon
Worked a little more on some kick pods I started awhile back... I don't like them so I already got new kick panels to rebuild but I will go ahead and use them for now. Sorry don't have a lot of pictures of the whole process it was kind of a lets see what I can do real quick.
Also I picked up a dash bezel from the junk yard... It was black and I couldn't have that.
Also scored a harness kit at the junk yard so I soldered it up.
Sorry I don't have a lot of in between photos but here is all of it installed.
Total cost on this whole cd player kick pod install... 101 dollars
Cd Player Kenwood Excelon KDC891... 92 dollars shipped on e-bay
Dash kit and harness......................... 3 dollars at junk yard
Rustoleum texture rattle can................6 dollars at Walmart
Rockford Comps................................. free were damaged in shipping and replaced and told to keep damaged ones (cones were cracked fixed with amazing goop)
Materials............................................ free left over from box build for a friend
This is just temporary until I rip the interior out and redo the entire dash.
Rebuild coming soon
I wasn't going to do audio anytime soon but I just can't stand "treble tripping", I need a little low end. I might see what I can come up over the weekend.
Rebuild coming soon
Didn't get a lot done today.... fell asleep after work
Here is a shot of the HIDs and interior light shots, HIDs are 8k and interior lights are supposed to be 8k colored bulbs
Rebuild coming soon
nice truck man good work as well i got a OBS ext cab GMC love it. You should sing up on on fullsizechevy there tons of parts and always new stuff for sale and its all trucks like that and newer and older ones as well.
keep up the good work.
Big Wheels Are Like G-Strings...Anyone can put them on but it don't mean they look good.....
Thanks...I have a build log going over there as well (same one)... I've learned a lot about these OBS trucks by just reading on there...
Rebuild coming soon
  • 7 months later...
So I Haven't really been updating because its been such a slow process so far. Things are starting to move along again.
Stock engine bay
New headers, breather, dist. cap, wires, valve covers and some other little dress up pieces.
New cab corners are in just not on yet so we pulled the bed to do that and start the bagging of the truck
Tank is going under bed so I removed this bracket
Welded in a support to keep everything lined up and add some bracing, also started notch and bridge but ran out of daylight shortly after.
Bought this little battery for the back for compressors and started a little battery tray, which will be welded onto the frame.
Got tank brackets drilled and figured out.
New to me but used 22s still need to clean them up
Air setup has been ordered and most of it has arrived.
2 480 viair compressors
Airlift 2600 bags
7gal under bed tanks
8 1/2 inch valves with 4 slow down mufflers for the dumps
Parallel 4 link
Watts link
Rebuild coming soon
Been working a lot lately so work on the silverado has been slow.
Cool picture of my Avalanche over in Ohio.
Well started cleaning the rims up
Well I had a high output alt from a previous build I deiced to use. I had to get a new plug from the junk yard and wire it to the brown wire. I did get it installed
Here is what happens when you are in a hurry and think you can hold the alt ring with your hand to drill it out.
Replaced front bumper finally
Then began bagging the front
I cut the spring pocket and then sprayed it to check for rubbing... I ended up doing this about 5 times
Here is just the drivers side done... I'm not notching for tie rods yet and will just lay air dam until I get more time to work on it.
Rebuild coming soon
