Bagged 94 silverado Build Log (delilah)
Got some SMC inline adjustable pressure valves (don't know the actual name of them) and a lower rated pressure switch. Worked on some slow air leaks, still got one tried the soapy water trick but still can't find this one. Started on some body work on the cab corners and some dings and dents on the cab. Actually drove it around a little bit tonight too... Rides like a rock, still haven't got shocks on it yet, maybe tomorrow.... Hopefully tomorrow I will get it all sanded down and ready for primer.
Rebuild coming soon
I love it man, comming along nice
''The Darkest Souls Are Not Those Wich Choose To Exist Within The Hell Of The Abyss, But Those Wich Choose To Break Free From The Abyss And Move Silently Amoung Us''
If you're still looking for a way to slow down the rear get some barb fitting from home depot for the exhaust ports on the valves.
Eta: never mind not all the posts were showing up on my iPad so I didnt see you got in-line regs
www.facebook.com/BILLatDivineCreationsPhoto
He was taunting me. He's all like "come at me bro!" So I'm like "I'm coming at you bro!" And he's like "hey, fuck you" *chomp*. Then I killed it. I win.
^^^ you have truly taken being a lazy fuck to a new level tonight, an MRE. WOW
Thank you
awesome job sr :good:
Thank you, first time doing this type of project learning a lot as I go and reading online.
Rebuild coming soon
Yesterday I sanded but did not get all the body work done. My plan was to just get it to the point where it was all the same color for slamology then I'd go back and finish the body work after. I ended up getting it primed but have decided not to take it to slamology, still have to put shocks on and I'm not even close to having the bed on today plus I still have a slow leak in my front passenger side that I can't find.... Anyways I ended up winning a little money at the casino last night and now I'm looking into buying upper and lower a arms from Michigan Metal Works along with the notchless tierod ends so that I can completely lay out up front, not sure If I want to or not. Here are some pictures, hopefully I will get some more today.
Rebuild coming soon
Not much to update. I found my leak, cracked brass fitting. Also welded on front and rear shock mounts. I have tubular lowering lower control arms and one of the little tab I welded on broke off before I even got home. So I'm going to have to redo those when I weld the rear brackets on. Hopefully I can use a lift next time so I don't have to weld laying on my back. Drove her around a little too before the shocks, its a little bumpy.
Rebuild coming soon
