Mechman Alternators
help with alt problems
i have a vid uploading if yall want to see that
thought it was my battery but my alt isnt charging at all,
maybe its my belt because it is the same one the puit on there(had to go to nissan to get this installed)
i have the positive from the alt going top my back battery
and the oem 4 gauge going to the front battery.
it was charging well for the first day then the 2nd day just crapped out.
vid coming soon
system:
changes way to much...
got my dad to jump my car, got them dmm out put it on ac voltage, put a prong to the 0 gauge and grounded the negative, it read 27 amps.. any ideas?
cars run on DC voltage, not AC voltage. and its voltage not amperage.
edit: as far as your problem goes, call mechman up
Edited by Kranny
Need an amp clamp or an inline ammeter that can handle 270+a to be able to test amperage on the car.
I got your email, give me a call when you can and we will see what's going on.
From what I am seeing in the video belt slip could be an issue. If it's slipping it will cause voltage surges like that. Also if any of the connections are loose it will be a problem too.
Edited by MECHMAN
so your brake light is coming on and it actrs like your brakes are causing it to tug............. and you havea 270 amp alternator with 4 gauge.....
it sounds to me like you are in over your head.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
  • Who's Online   1 Member, 0 Anonymous, 791 Guests (See full list)
